| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Need Chengine Temperature Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hey !
Can anyone tell me what the temperature range is of an 80cc Chengine ?...  |
11-03-2008, 01:23 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2008
| | Need Chengine Temperature Hey !
Can anyone tell me what the temperature range is of an 80cc Chengine ? |
11-03-2008, 07:13 AM
| | Re: Need Chengine Temperature Head temp., exhaust gas temp., or ????
11-03-2008, 08:12 AM
|  | MANIC Mechanic | | Join Date: Sep 2008 Location: Clearwater, FL
| | Re: Need Chengine Temperature Hello,
We shot ours wth a temp gun after 15 minutes of running...the cylinder head was 170-180.
Jim |
11-03-2008, 08:23 AM
| | Re: Need Chengine Temperature Hello Jim and Joe,
Thanks for the reply, 170-180, will do for now, but if you have both the
Head temp., exhaust gas temp, available, great!
I know that the boiling point of water is 212 degrees Fahrenheit, so can I assume the 170-180 is Fahrenheit ? |
11-03-2008, 08:33 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: WEST FRANKFORT, IL
| | Re: Need Chengine Temperature I Know That My Engine Used To Boil The Fuel In The Carb With The Stock Rear Sprocket . Now That Ive Switched I Havent Had That Problem So I Can Only Assume That The Temp Is Reduced. Something To Consider
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
11-03-2008, 08:58 AM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: paso robles, california
| | Re: Need Chengine Temperature can run as hot as 250-275 degrees fahrenheit. at about 320 the paint on the cyclinder starts to brown, thats a little hot. mine hits 250-275 all the time climbing hills. checked with temp gun. |
11-03-2008, 05:14 PM
| | Re: Need Chengine Temperature Exhaust gas temp should never go above 1200F. 1000-1100 at cruise is ideal.
11-03-2008, 08:12 PM
| | Re: Need Chengine Temperature Quote:
Originally Posted by OSCAR383 I Know That My Engine Used To Boil The Fuel In The Carb With The Stock Rear Sprocket . Now That Ive Switched I Havent Had That Problem So I Can Only Assume That The Temp Is Reduced. Something To Consider | Just curious... how do you know it was boiling the fuel? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:36 PM. | | |
