| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Need advice tuning PHBG carby Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello all! I have just been testing a dellorto replica PHBG carby. This carby is 19mm and conveniently fits over ...  | |
08-20-2008, 09:23 PM
| | Senior Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Australia
| | Need advice tuning PHBG carby Hello all! I have just been testing a dellorto replica PHBG carby. This carby is 19mm and conveniently fits over the stock manifold but this restrict is down to around 16-17mm (I have the thin walled crome type). Will this greatly affect performance and tuning while waiting to get a full sized one made up. Incidently my 70cc engine has a inlet port way bigger than the stock 14mm its more like an oval 19mm.
Now it came with a huge 0.90mm jet, I used my stock jet (0.70)mm which was still far too rich but it did run. I bogged up the 0.90mm carby with a fuel proof epoxy putty and put a hole in it using guitar string which I am guessing is 0.50mm. This time it ran much better on the leanest clip setting in fact at low revs it seemed like the right mixture, no smoke or anything! BUT... as soon as the throttle opened up it bogged down losing power.
Now I know it is pretty close but I need advice as to where to go from here.
Would it be that the jet is now too small and the bogging is due to fuel starvation once the jet rules at open throttle?
OR, is there fuel collecting at the step down in diameter to the manifold?
OR, is the taper on the pin too steep (it looks steep)?
OR, is the jet still too large. This carby has a proper circuit which draws air into the emulsion tube surrounding the pin unlike the stock carby which only draws from the top only. I went to such a small jet because mopeds, which have similar engine specs run Dellorto's using 0.50- 0.55mm jets.
My feeling is that it is still too rich because I am running at the leanest clip setting. Maybe I need a smaller guitar string! |
08-20-2008, 10:11 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Need advice tuning PHBG carby I believe your jet is too small at WOT, and it is too big at mid range with not enough adjustment in the needle. I just got done jetting a 18mm mikuni, and I ran into the same problem. I first tried notching the needle one more at the top, and that almost did it, but eventually had to make the slide cutaway larger to allow more air at low and midrange. I am not familar with your carb, but they all work the same. If the slide is round the cutaway is on the air filter side, and usually will have material removed from 1.0mm to 3.0mm, mine was a 1.0 and I removed 1.0mm to make it a 2.0 and then I was able to move the clip back down because I know have more airflow. You could also try a fatter needle if avail., for less fuel at low RPM. |
08-20-2008, 11:05 PM
| | Re: Need advice tuning PHBG carby Good advice thank you! I just studied the Dellorto tuning manual and I understand what you are saying about the needle.
There is no room for a higher notch on the needle but I could drill into the slide body a bit to lower the needle more. As for the cut away I am assuming you are talking about the angled cut at the back of the slide well this is 3-4mm high. There is no cut away at the leading edge at all.
Hmmmmmmm.
I might try to lower the needle by 1mm and increase the jet size a bit. |
08-20-2008, 11:34 PM
| | Re: Need advice tuning PHBG carby Another thought I had was you might compare the stock HT needle to yours, thickness, length. My Ht needle was the same length but was much thinner, so the slide is the only way to go for me. I dont undestand the cutaway being on the engine side, every one I have seen has been on the air filter side of the carb. I dont see how it would help on the trailing side of the slide.
Is this the carb you have? This diagram shows the cutaway on the air filter side.... PHBG Carburetor Parts [PHBG Parts] - $0.00 : Dellorto Carburetors, And parts for you.
08-21-2008, 04:40 AM
| | Senior Motorized Bicycle Builder | | Join Date: Feb 2008
| | Re: Need advice tuning PHBG carby I am also trying to tune one of these to a 70cc HT.
I still have some way to go yet. It runs with a .60, but rough and rich.
I think I still need a smaller idle jet as the screw has little effect.
Also part #3 needs to be a "2 stroke" atomizer, the copies are usually fitted with the wrong 4 stroke part.
see the dellorto documentation for more info.
it is possible to solder up the holes in the wrong part though.
Also watch the engine end of the carb. the idle circuit vents there and can also suck air if not sealed with a rubber boot. Additionally its easy to block this outlet when fitting the carby on the manifold too far. |
08-21-2008, 07:09 PM
| | Re: Need advice tuning PHBG carby Sorry the cut-away is on the air filter side and yes that link is for my carby.
Yeah I studied the tuners handbook from Dellorto and was wondering about the atomiser. I think it has got the 4-stroke type which is no good, I guess I'll have to block some up.
By the way Quick Steel epoxy putty seems to hold up under constant fuel and sticks to metal well I have had success bogging up jets with this stuff.
I ran it with the jet from the stock carby first and it was rich as **** which is why I have gone so small. I'm guessing 0.50mm. I feel the jetting is nearly there I'm going with the advice on the pin. I noticed that the clip is too wide to fit in the indentation on the slide so it is out 1mm further than it should be. I am going to drill into the slide a bit and then top the clip with a washer so I can get another couple of settings leaner.
If this fails then it looks like I might be bogging my atomizer holes. |
08-21-2008, 07:15 PM
| | Re: Need advice tuning PHBG carby |
08-22-2008, 02:27 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Mesa, AZ
| | Re: Need advice tuning PHBG carby RL, I ordered up one of the 2 stroke 15mm PHBG, so we'll see how it does.
Any idea where to get a jetting kit for the PHBG? Would like to have a few needles, atomizers, and idle jets to play with. |
08-22-2008, 02:35 PM
| | Re: Need advice tuning PHBG carby Found this nice link for tuning the PHBG. Has a very nice chart of the needle sizes available as well as info on getting the engine tuned right to the sweet spot. How To Tune PHBG Carburetors - MopedWiki |
08-23-2008, 10:55 AM
| | Re: Need advice tuning PHBG carby Good link Datz! Awesome news that you got the 15mm PHBG AS. I reckon it will be the winner. Did you get to choose what jet it comes with? Interested to see what comes as stock. Remember to try your jet off the Ht carby as they fit the PHBG when tuning.
I am guessing that a 0.55 will be right for my 19mm PHBG. Doesn't necessarily mean that your smaller one will though. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 07:51 PM. | | |
