N A S A We have a problem!!!!!!!!!!!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. ok, i over tightened my head bolts and have stripped out my threads down in the crank. What size should ...
Old 06-07-2009, 08:54 PM
toker_ace's Avatar
Default N A S A We have a problem!!!!!!!!!!!
ok, i over tightened my head bolts and have stripped out my threads down in the crank. What size should i tapp out the threads? PABLO???????????????? lol.
Old 06-07-2009, 09:14 PM
Default Re: N A S A We have a problem!!!!!!!!!!!
go to an american size that is comparable to the current metric size.. american will be just slightly larger. just tap it out and be careful... done stuff like that many times..
you'll want 16 thread
Old 06-07-2009, 09:58 PM
Pablo's Avatar
What size are you starting with? (is it 6mm or 8mm?)
Did the threads pull out?
Old 06-07-2009, 10:52 PM
Retmachinist's Avatar
Jeff, I thought you said you had a torque wrench. LOL If you get into big problems give me a call, might have to heli coil it or I can make you some special studs.
Maybe the book was right when it said head bolt torque 10 Ft. Pounds?
John
Old 06-08-2009, 04:05 AM
toker_ace's Avatar
i,m not sure which size pablo. i'll find out. i figure i can just tapp them out into a standard size. i just hope i can find some bolts. are head bolts special like grade 8?
Old 06-08-2009, 05:54 AM
toker_ace's Avatar
the bolts are 6mm.
Old 06-08-2009, 06:30 AM
the bolts are 6mm.
Jeff, You can either go to 8 MM or 5/16. The same size within about .003, just a different thread. I wouldn't worry about trying to find a grade 8 bolt.
John
Old 06-08-2009, 07:23 AM
toker_ace's Avatar
hey john. i put my other head back on. i had an extra head bolt. now i have about half the power and will not idle. i sprayed the head with wd-40 with it running and no high revs. so that should tell me if i have a leak right? i put some gasket silicon underneath the jug and the crank case. i wonder if that is causing my problem? if i choke it while its running it wants to kill the motor, which is good. there isn't any certain way to put the jug back on the piston is there? i just slide it back over the piston. sever lose of power. no more raddle.....lol!
  #9 (permalink)
Old 06-08-2009, 08:06 AM
Pablo's Avatar
So the stud was stripped? Typical.
You probably have a head gasket leak. Research the aluminum paint trick and use a new gasket. Maybe get 4 new studs, so you can torque it up good. I went to 20 ft. #'s on mine, but they are 8mm. Sealed tight.
With 6mm......hmm......maybe 14 max.
LUBE and Compress the rings as you slide the cylinder on carefully.
  #10 (permalink)
Old 06-08-2009, 09:22 AM
Finfan's Avatar
A 1/4" is slightly larger than 6mm. I had one of the studs strip like that and I just used JB Weld to fasten it back in. That was about 500 miles ago and it is still holding. If it ever does pull loose you can still tap it out to a larger size. Good luck! There is always something with these kits!
-and-
I'm not lost, I'm exploring!
