My Mo-Bike is finally done!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I've finally completed my bike so that I feel like it is ready to ride. It all started out ...
Old 05-25-2009, 09:56 PM
Smile My Mo-Bike is finally done!
started out last November with just the basic bike and motor kit. What
I ended up with was this: Front and rear drum brakes laced with 12 gauge
spokes and motorcycle wheel bearings, Mikuni 18mm carb, 1986 Harley
Davidson Sportster2.2 gal. tank (E-Bay),12 volt 4.5 amp lead acid gel battery
mounted in a aluminum box, 12 volt 40 watt lawn tractor head light with 12v
LED tail light with brake light that works off of a 1972 Triumph/BSA front brake
cable with micro switch,Boost bottle, speedometer/odometer, tachometer with
time log. custom expansion chamber and custom chain tensioner wheel with 2
ball bearings. Top speed 41 mph (screaming at 7200 rpm) with a 41 tooth
sprocket. It will cruise comfortably around 35mph , which is fine with me.
I plan on installing a slant head on it next, to see how much if any improvement
shows. It's been more time consuming and more difficult than I thought it would
be. In fact I'd be a little embarrassed to admit how many days and hours I've
put into it. But, most of it has been fun though.
Old 05-25-2009, 10:50 PM
Dan's Avatar
Dan Dan is offline
Default Re: My Mo-Bike is finally done!
Man OR!! How ever long it took, well worth it! Really beautiful work.
Originally Posted by NEAT TIMES View Post
looking In The Sky, May See Dan Flying By!! Ha Ha Ron
I want 2 ride my bicycle
Old 05-26-2009, 12:52 AM
Creative Engineering's Avatar
MANIC Mechanic
REALLY REALLY NICE Outrunner!!!
I wouldn't be the least bit embarrassed about the time! Quality builds take time!
I see a familiar machined part on that bike...I'm proud to be part of it!
Jim
Old 05-26-2009, 03:46 AM
Wow really nice build there.That is a classic
Old 05-26-2009, 06:10 AM
Wink Re: My Mo-Bike is finally done!
Jim
Jim, Yes, you are right. I forgot to add that I also have Creative Engineering's
clutch actuater kit. It's really the only RIGHT way to set up your clutch so that
it works smooth and easy, I love it! Thanks for the compliment too.
Fred
Old 05-26-2009, 07:39 AM
Retmachinist's Avatar
Outrunner, that is a beautiful build, and I know what you mean about time spent. I don't tell people how many hours I have in mine but like Jim says a real quality build takes time.
That sounds and looks like a really safe bike to ride. That is also one of my main concerns. At my age I wouldn't take a crash very well. Great Job!
John
Old 05-26-2009, 07:40 AM
old motorbike's Avatar
Very great build. outstanding classic look.
Old 05-26-2009, 05:29 PM
2door's Avatar
Beautiful, simply beautiful. That's a piece of work...and I mean that in the best way. Congratulations on a quality first build.
Over Youth and Skill
  #9 (permalink)
Old 05-27-2009, 10:16 AM
It is inspiring to see a really wonderful bike. Your attention to details are obvious. Best of Luck with it. Can you please share your set up and jetting of the Mikuni carb
Gene
  #10 (permalink)
Old 05-27-2009, 09:41 PM
Arrow Re: My Mo-Bike is finally done!
Gene
First thanks guys for the compliments I really appreciate them!
The 18mm Mikuni carb #VM18-144 comes with an 80 main jet, which is a little
on the rich side at top end, so I've got some various jet sizes above and below
the stock ones on order. I plan on using a 70 or 75 main jet. Currently I've located the 5 notch needle clip to the top, making it as lean as it can. It accelerates very
well and has rapid throttle response also. In order to mount the Mikuni, I had to
use a short piece of PVC tubing in order to reduce the spigot mounting inside
diameter, so that it would fit the intake manifold.That worked real well.I've been
trying to mount a UNI Filter to it, but so far I haven't gotten a good fit, so I'll
have to do some more mods to the filter and mount.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/my-mo-bike-finally-done-8374.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 05-26-2009 01:44 AM
