my first build is broke down
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. No thats the clutch...other side, look at previous post...
  #21 (permalink)
Old 12-09-2008, 10:11 PM
fairracing31's Avatar
Default Re: my first build is broke down
Interested in Alternative Energy? http://nature2energy.com/
  #22 (permalink)
Old 12-09-2008, 10:26 PM
jimmybking's Avatar
i was trying to take that nut off and i dont know how. it seams to keep spinning even if i have something holging my tire in place.
  #23 (permalink)
Old 12-09-2008, 10:32 PM
Well your clutch is slipping....are you sure its backfiring? Or are you just turning the motor over while trying to start it and what you hear is the motor turning and not a backfire?
  #24 (permalink)
Old 12-09-2008, 10:33 PM
You dont have the clutch lever locked right?
  #25 (permalink)
Old 12-09-2008, 10:37 PM
jimmybking's Avatar
whenever i would let the clutch lever out the motor would turn over like its supose to then it would spit and sputter going down the street, jumping around a lot. then it sounded like a back fire and would start spit and sputter again.
  #26 (permalink)
Old 12-09-2008, 10:38 PM
jimmybking's Avatar
what do you mean its not locked right?
  #27 (permalink)
Old 12-09-2008, 10:42 PM
Okay now that you described it in that way...do you have another spark plug to swap out? Lets eliminate the possibility of a fouled spark plug
  #28 (permalink)
Old 12-09-2008, 10:45 PM
jimmybking's Avatar
i got one in my new build ill give it a try.
  #29 (permalink)
Old 12-09-2008, 10:52 PM
Be sure to use the tickler (primer) and choke. If thats not it you want to check to be sure you do not have any vacuum leaks.
I've got to go...I will try to check back tonight
  #30 (permalink)
Old 12-09-2008, 10:54 PM
jimmybking's Avatar
i tried to use my new spark plug but the thing is so darn tight in the motor it striped the tool that comes with the kit and i dont have a deep well socket. but it was firing, just really porely, do spark plugs, when going bad, only fire half of the time? or is it one way or another, they work or they dont?
