| Sponsors
| | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Motorized Bike Lurching a Bit Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Mine lurches a little from time to time. I discovered when it was not getting my fuel valve fully turned ...  | |
03-02-2008, 08:35 AM
| | Re: Motorized Bike Lurching a Bit Mine lurches a little from time to time. I discovered when it was not getting my fuel valve fully turned on. I have learned exactly where the valve goes now and have had no more problems. Thats probably not what ya'lls problems are but you never know..........................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
03-02-2008, 11:37 AM
| | Re: Motorized Bike Lurching a Bit These engines are not exactly torque monsters, so when not at the top of high rpm torque curve they will buck a bit. Always happens when breaking them in, but will get better with time.
It's also a matter of plug selection (NGK B5HS and do the wire upgrade), fuel control, fuel oil mixture (IE tuning)
Not sure what part of the country you are from, but when cold the problem is exacerbated. Mine takes farting forever to get warm when ambient is at 50°F or below. |
03-02-2008, 06:04 PM
| | Re: Motorized Bike Lurching a Bit There is 101 ways these bikes will lurch We've covered 5 or 6 reasons. You all have good inputs on reasons why. Running out of fuel or starvation at high rpm will do it and so will too low of rpm cruising. Spark can cause it but I'm still stubborn and running the stock plug. I changed the plug wire out to an industrial wire which for me didn't improve my problem one bit it turned out to be my stock plug getting fowled out. I blast cleaned the plug and I'm still using it with no problems. High rpm and the lurching for me was not having the fuel valve on all the way. I know that's what got Bob as well. A short in the wiring will do it and can be hard to find. Run your hand over the wires while its running if you think it might be the cause. You will know if it is cause you'll get lit up if you've got just one strand of the wire sticking out and touching the frame now and them. I found that out, that thing will bite!
Wet climates will short out the kill switch and wet wiring can cause it as well.
Anyone else got one?
Here's my last if you buy one of these engine kits it can and will do all sorts of hateful thing if you let your guard down. But that is sort of the fun isn't it?!
Norman |
03-02-2008, 06:36 PM
| | Re: Motorized Bike Lurching a Bit This lurch thing reminds me of my third x wife. She came home cursing because she had to buy an alternator on the road. the man asked her didn't you hear the bearings grinding. She said I heard a grinding sound but I turned up the radio.
Sounds like thats the best thing to do with the lurch, turn up the radio except the other noises would drown out the radio. At least on my bike they would. |
03-03-2008, 09:30 AM
| | Motor Bicycle Apprentice | | Join Date: Feb 2008
| | Re: Motorized Bike Lurching a Bit Quote:
Originally Posted by deacon ...didn't you hear the bearings grinding. She said I heard a grinding sound but I turned up the radio... | Deacon - I did indeed turn-up the radio!  In fact, I gave it more throttle and the lurching stopped. It appears that the combination of running at (too) low rpms and babying the motor during break-in caused the lurching. The little sucker loves the throttle and has started to purr a wee bit as I have given it more and as it breaks in. I live in a hilly area and am finding that the stock sprocket works pretty well - enough torque to get up the (moderate hills) with enough speed to keep it interesting.
I'm impressed with the little engine. It runs smoothly (so far) and fairly quietly. It sounds like I'm riding my chainsaw!  I'm running stock plug wire and plug and built a wiring harness for it; therefore, shorting / grounding potential is minimized (hopefully). The gears make the characteristic whine. I'll try a wee bit of grease as I've seen in some posts. The chain is stretching; gonna have to take out a link soon. |
03-03-2008, 09:35 AM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: Motorized Bike Lurching a Bit it will just get better and better. i could not believe when it broke in. you will know it. all of a sudden it goes and it sounds better. first engine i every had that i knew it was broken in. how long it takes i am not sure for every one of these bicycle engines is different and they sure are fun  |
03-03-2008, 09:37 AM
| | Re: Motorized Bike Lurching a Bit That chain is a thorn in my side. I have a new one that does better as far as stretching but it will still 'move' the rear wheel forward after a while. I run a cruiser frame. |
03-03-2008, 01:13 PM
| | Re: Chain Tension / Rear Wheel Movement You know... I've been toying with the idea of designing a clamp that allows 1) positive locking of rear wheel (can't shift out of the drops) and 2) uses a threaded fastener to adjust the location of the wheel in the drops. It would actually have to be a pair of clamps that sit on both sides - both drops. I envision something that would allow for fine tuning chain tension and trueness of the wheel (...how parallel it is to the centerline of the bicycle).
Ever come across something like that? I've seen 'locks' on front wheels but not the adjusting functionality. |
03-03-2008, 03:36 PM
Originally Posted by angus Deacon - It appears that the combination of running at (too) low rpms and babying the motor during break-in caused the lurching. The little sucker loves the throttle and has started to purr a wee bit as I have given it more and as it breaks in. Definitely give it the throttle! Don't baby it past the first 5 minutes.
I'm impressed with the little engine. It runs smoothly (so far) and fairly quietly. It sounds like I'm riding my chainsaw!  I'm running stock plug wire and plug and built a wiring harness for it; therefore, shorting / grounding potential is minimized (hopefully). A good plug/wire/cap will do you a world of good...try it, you'll like it.
The gears make the characteristic whine. I'll try a wee bit of grease as I've seen in some posts. The chain is stretching; gonna have to take out a link soon. Lithium, or white grease is best, don't get crazy with it! | .................................................. .................................................. ....
03-03-2008, 04:14 PM
| | Re: Motorized Bike Lurching a Bit Most all motorcycles have chain adjusters on the axles the ones that don't use drive shafts. My Harley runs a belt but it is like a chain and it too has adjusters to get the belt to the proper tension which when right seems tight to me.. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:44 AM. | | |
