| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Motor starting to miss Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I completed my bike build and have been really happy with the results. I have run about two gallons of ...  |
05-21-2008, 11:26 AM
| | Motorized Bicycle Apprentice | | Join Date: May 2008
| | Motor starting to miss I completed my bike build and have been really happy with the results. I have run about two gallons of gas through it and it is starting to misfire especially if I am going up a hill. I started this hobby as a way to learn something about motors. I would appreciate some help in what I should try first to fix this. I could take it to a local shop but would like to try to fix it myself first. Isn't it always more fun to take it to the shop after screwing it up yourself first. Any help would be greatly appreciated.
Thanks. |
05-21-2008, 11:54 AM
|  | Moderator | | Join Date: Dec 2007 Location: Gainesville, FL
| | Re: Motor starting to miss What size/type of motor are you running?
__________________ |
05-21-2008, 12:41 PM
| | Re: Motor starting to miss It looks to be the same as the one pictured on your bike (the traditional motor kit from China). I purchased it from Kings, it is the one they sell as an 80cc which as I read from posts here it closer to 67cc.
Thanks. |
05-21-2008, 12:44 PM
|  | Master Motorized Bicycle Builder | | Join Date: Dec 2007 Location: Essex, UK
| | Re: Motor starting to miss Have a look at the plug to see if the engine is running lean/rich - it could be running lean under load which may explain the misfire.
If the mixture is ok then you should get a dry plug tip with a tan/brown colouration.
Other problems could be to do with the ignition and also the petroil mix (if you are running a two stroke).
hope that helps
Jemma xx |
05-21-2008, 01:11 PM
| | Re: Motor starting to miss What ratio of oil to gas do you recommend? |
05-21-2008, 01:18 PM
| | Re: Motor starting to miss After break in I run mine 30 to 1.............
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
05-21-2008, 02:05 PM
| | Re: Motor starting to miss So uphill it "misses"....give me a slight more amount of info...does the engine go flat for power, or does it just "pop" a miss....???
Indeed get a new NGK plug and a nice 7mm auto sp wire with 90° boot.
Then use a good oil at 25:1 or 30:1, depending
What needle slot are you using?
Remember a 67 cc engine is not a torque monster. I think the compression ratio is really low, so again this limits torque - plus worst of all the power band is narrow and you ain't got gears to keep the power in the band.
Also, you can check for intake tube leaks and match the intake and exhaust ports. The intake manifold is a notorious bad match to the port PLUS is has weld protrusion that you can clean up. |
05-21-2008, 02:19 PM
| | Re: Motor starting to miss Sounds like they have you covered.
The sounds coming from these engines can fool you but if it has been running good and is now missing I would vote ignition plug and wire. |
05-21-2008, 02:30 PM
| | Re: Motor starting to miss Thanks for the help, I ride on a pretty consistent route and it seems that your description of the "engine going flat for power" is a better description of what happens. I ride the same hills and have gotten used to a certain performance level and feel that I have fallen below that. I am embarassed to ask but what is a NGK sparkplug?
What are the plug signs that the engine is running lean or rich?
Thanks for taking the time to help me out. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:57 AM. | | | Sponsors
