motor bicycle gas tank leak
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. what is the best way to find and fix a leak in a gas tank. its not at the petcock ...
Old 01-17-2008, 09:23 AM
CRUISER's Avatar
ADMINISTRATOR
Default motor bicycle gas tank leak
what is the best way to find and fix a leak in a gas tank. its not at the petcock but some where on the tank and so small hard to find it?
http://stockmarketcats.com/
Old 01-17-2008, 09:54 AM
Norman's Avatar
LORD VADER Moderator
Default Re: gas tank leak
You know I was wondering when someone was going to ask this. You can get hurt or killed fixing a fuel tank.
Here's a product in the J&P catalog 1-800-397-4844 called Kreem #702-469 and sells for $29.99 it will repair the leak. you can also go to Parts For Your Harley®, Honda Motorcycle Parts - J&P Cycles® that's the safe way to do it.
Now the dangerous way. Empty the tank and flush it wit hot soapy water and I mean lots air out and do it again at least 3 times. Seal up the tank and put it in a tub of water just like you do when looking for a hole in your tire. When you find the leaking spot mark it so you will know where it is. Clean the area good with sand paper do this by hand don't want any sparks and to bare metal. Now of the part that can really get you hurt. Small leaks can be soldered with the type of solder that plumbers use and the use of a propane torch that heats up one of those large soldering irons. Or by direct heat from the torch. And you can also oxy weld it. The most important thing is the use of an inert gas in the tank while doing this and that's the catch. The use of exhaust gas works where you afix a hose to the cars exhaust and stick the other end in the tank you are working on or the use of nitrogen purging in the tank while you are doing the work. You see there's a bunch of ways things can go wrong and it will or can burn you or blow up and kill you and others. If I didn't scare you enough not to do then good luck. I've been involved i tank repairs for many years 1000 bbl tanks and tons of training and we use very special tools that the average Joe doesn't have. So there you go a safe way and a dangerous way.
the address of jpcycles is in the edit box.
Norman
Old 01-17-2008, 11:50 AM
MotorbikeMike's Avatar
Dealer
OR you can just buy a new tank? I too repair my own tanks as needed, but it is a very risky business.
On a good steel tank I use oxy-actelyn thinner I use propane and lead solder.
Typically these tanks will leak if overtightned, the brazed on studs on the bottom will begin to weep. MIGHT be able to use JB weld on a thing like that, otherwise it is purge and re-braze.
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
Old 01-17-2008, 11:56 AM
Norman's Avatar
Mike
your right on what you said I left out the option of buying a new tank and how the leak might of started in the first place.
Norman
Old 01-17-2008, 01:39 PM
CRUISER's Avatar
ADMINISTRATOR
guess i am going to need one of them 1 gallon tanks you have motorbikemike
Old 01-17-2008, 02:18 PM
Dealer
Cruiser, I'm ready when you are! Work is picking up a little around here, I've got a Whizzer to dis-assemble and ship, one coming in for 100 mile service, and an old WC-1 coming in for a general check-up. I really like service work, I wish I had 1000 customers here locally!
I need to get off my butt, and get some pics taken of ror sale items also!
Mike
Old 01-18-2008, 05:41 PM
iRide Customs's Avatar
Mike
Great idea Mike! The more the merrier I always say.
If you don't have much mechanical know how, buy a new one. The Kreem tank sealer cn be a huge pain in the butt and very messy if you are not prepared.
Dan
Live life like you mean it...RIDE!!
……...Q
…...(_\g
..(_)/(_)
Old 01-18-2008, 05:45 PM
CRUISER's Avatar
ADMINISTRATOR
i been wanting a gallon gas tank since i like to do long rides. glad you all talked me outa repairing mine. strange thing is it leaked for about 3 days and now has stopped leaking but still getting my gallon tank from motorbikemike as soon as i get back from hawaii
  #9 (permalink)
Old 01-25-2008, 09:58 AM
CRUISER's Avatar
ADMINISTRATOR
started leaking again but located the leak. it is where the screws come out the bottom to mount it. not sure if i am going to try to repair it or not. at least i know where it is coming from
Similar Threads
motor bicycle pictures Norman Pictures and Videos 13 05-27-2008 04:50 PM
California Motor bicycle Law MotorbikeMike Laws and Legislation 10 04-10-2008 10:08 AM
gas leak CRUISER Bicycle Engine Kits 12 02-22-2008 11:24 AM
motor bicycle clutch Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 7 02-11-2008 07:04 AM
ladies motor bicycle biker Motorized Bicycle General Discussion 11 01-05-2008 10:23 AM
