| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | more top end speed after run in Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. will my 70cc happytime motor gain more top speed after run in cauce i have done 50km and it can ...  | |
12-24-2008, 12:49 AM
|  | Motorized Bicycle Senior Member | | Join Date: Aug 2008 Location: Coffs Harbour, Australia
| | more top end speed after run in will my 70cc happytime motor gain more top speed after run in cauce i have done 50km and it can only get up to about 40km?? Could it could be cauce i am not getting enough air into the carby?
Thanks |
12-24-2008, 07:03 AM
| | Re: more top end speed after run in I have had kits that ranged from 25 mph (40 kph) to over 35 mph (60 kph).
A lot depends on the engine, which intake it has, how well the ports are matched, what type of muffler, ect.
Most all of them can be made to run 50-60 kph with a little work.
Break-in does help, but I think a lot of it is due to "tweaking the engine and components" during the break-in period.
12-24-2008, 07:04 AM
| | Re: more top end speed after run in How is your mixture? What color is the plug?...that's where I'd start.
12-28-2008, 04:22 AM
| | Re: more top end speed after run in well i am running 20 to 1 and the plug is a nice brown colour!! |
12-28-2008, 07:32 AM
| | Re: more top end speed after run in You'll get a little more power and maybe speed if you go to 24 to 1, or even 30-32 to 1 synthetic oil.
How's the break-in going? Has it picked up any speed yet?
12-28-2008, 07:38 AM
|  | MB Builder Extraordinaire | | Join Date: Jul 2008 Location: coventry, RI
| | Re: more top end speed after run in i noticed a big difference in out-of-the-box power, between bushing and bearing motors.
bushing motors were quick from the start, but bearing motors dont achieve total power until you're into the third tank.
its a new motor. everything's tight, and the rings havent seated yet.
__________________ New, fully assembled motored bikes here: http://happytimecycles.wordpress.com/ 401-952-7064 Quote:
Originally Posted by Dan sn0rk. | Quote:
Originally Posted by Bikeguy Joe You are one sick man spun, I like that quality in a person. | A 20-year smoker, I quit smoking with the help of this--->http://www.premiumecigarette.com/415.html a smokeless, non-tobacco electronic cigarette. |
12-29-2008, 05:11 AM
| | Re: more top end speed after run in well when i first got it, it had a bit of power but no top speed so i drilled some holes in the carby filter cover and that made a bit of a different to the top speed but it seems to be not getting enough air.
Like when i ride i can put it full and it will get up too a speed and then the exhaust will make a vibration noise and it just wont go no more.
Thanks |
12-29-2008, 03:55 PM
| | Re: more top end speed after run in Have you checked your motor mounts? It is possible the fuel is foaming in the carb due to lose mounts or excess vibration.  |
12-30-2008, 06:27 PM
| | Re: more top end speed after run in well I have rubber between the frame and the mounts,and it is a smooth to ride.
Thanks |
12-30-2008, 07:36 PM
| | Re: more top end speed after run in Sound like it is going into a four cycle when it "gets there". Try a leaner carb setting. (one notch up on the needle.)
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:27 AM. | | | Sponsors
