| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | more chain problems Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I finally got around to tinkering with my Mb again.. made a chain tensioner bracket simmilar to what 2door has ...  | |
07-05-2009, 09:15 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: usa
| | more chain problems I finally got around to tinkering with my Mb again.. made a chain tensioner bracket simmilar to what 2door has except mine is bolted to the chainstays with 6mm bolts, and it uses a TSC tensioner, just without the spring.... the rear sprocket is a rag joint sprocket but it's running completly true and it's tight... problem comes with tension on the chain.. it will start to jump teeth and ride ontop them if it's got tension on it.. let the tension off and it tracks perfectly... any idea's? |
07-05-2009, 10:10 PM
|  | MANIC Mechanic | | Join Date: Sep 2008 Location: Clearwater, FL
| | Re: more chain problems Quote:
Originally Posted by matt167 I finally got around to tinkering with my Mb again.. made a chain tensioner bracket simmilar to what 2door has except mine is bolted to the chainstays with 6mm bolts, and it uses a TSC tensioner, just without the spring.... the rear sprocket is a rag joint sprocket but it's running completly true and it's tight... problem comes with tension on the chain.. it will start to jump teeth and ride ontop them if it's got tension on it.. let the tension off and it tracks perfectly... any idea's? | Matt,
Can you post pics?
Jim |
07-05-2009, 10:44 PM
| | Re: more chain problems Matt,
First question is, are you running the kit supplied 415 chain? I've seen twists and kinks in some of them. I've seen rollers that didn't roll and chain that had a natural twist in it that I couldn't get out. It's the first thing I replace. Look for a good quality #41 chain available at Ace Hardware, Tractor Supply and Grainer to name a few.
The next thing is chain alignment. Is your tensioner guiding the chain onto the rear sprocket correctly? The tensioner wheel MUST be aligned with the chain path and not pulling the chain to either side. Get back to us with some pictures and details.
Over Youth and Skill |
07-05-2009, 11:56 PM
| | Re: more chain problems yea, I'm using the kit supplied 415 chain. I used nuts to space the tensioner slider away from the spokes and allign it with the sprocket/chain.. I'll get some pics tomorrow..
I'll probably get some #41 chain.. after all this chain has been beat up a bit from the other tensioner mishap's I'v had.. |
07-06-2009, 08:27 AM
| | Re: more chain problems Sounds like you may have bent a few links.
07-06-2009, 08:52 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2008
Originally Posted by Bikeguy Joe Sounds like you may have bent a few links. | with that truck supply roller and bracket on a setup like 2door does, you have to tweak that bracket to get it lined up right...that 41 chain is going to give you some grace,but you must watch for clearance between chain and tire...also if you are using the truck supply bracket and roller, you must use a set screw on the bracket so if it moves it doesnt go all the way down....than you will have a chain problem...all in all, good idea but pay attention to application...Dennis |
07-06-2009, 12:17 PM
| | Re: more chain problems It's all set up and alligned perfectly. the only thing I didn't do was use a set screw to hold it in place.. I just tightened it in the down position. to adjust tightness, I just move it up the slot instead of rotating the tensioner into the chain |
07-06-2009, 12:19 PM
Originally Posted by Bikeguy Joe Sounds like you may have bent a few links. | probably.. I'm gonna pull it off today and see how mangled it really is. |
07-06-2009, 02:28 PM
Originally Posted by matt167 It's all set up and alligned perfectly. the only thing I didn't do was use a set screw to hold it in place.. I just tightened it in the down position. to adjust tightness, I just move it up the slot instead of rotating the tensioner into the chain | good for you...i no my prototype needs the bracket bent alittle...it attachs to the frame and is simular to 2doors...probably a old generator bracket would work fine...every bike is different...when you get it finished give us a pick...tensioners are a good topic on the forum...have fun...Dennis |
07-06-2009, 03:42 PM
Originally Posted by drhofferber good for you...i no my prototype needs the bracket bent alittle...it attachs to the frame and is simular to 2doors...probably a old generator bracket would work fine...every bike is different...when you get it finished give us a pick...tensioners are a good topic on the forum...have fun...Dennis | Dennis,
That is an excellent idea. Find the top generator or alternator adjusting bracket. The most common you'll find will have a 3/8" slot in it and most tensioner/roller blade/skate board wheels use a 5/16/ bolt but they make bushings to take up that difference. Why didn't I think of that before I spent the time milling a slot and bending my bracket  I think, if I scrounge through some of my old hot rod stuff, I have a chrome one.
Good idea.
Over Youth and Skill | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:33 PM. | | | Sponsors
