Re: Micargi Falcon GTS It will fit, I built a Macargi similar to it. The front down tube is approx. 1 1/2". You will have to figure out a mount for it. A U clamp through a flat plate bolted to the motor holes will probably work the best. You won't have to drill holes in your frame that way.
John |
