| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Major clutch arm problems Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. My clutch arm moves around freely and doesn't hit against anything. So of course its not starting, I have the ...  |
02-21-2010, 07:53 AM
| | Motorized Bicycle Newbie | | Join Date: Feb 2010 Location: Menomonee Falls Wisconsin
| | Major clutch arm problems My clutch arm moves around freely and doesn't hit against anything. So of course its not starting, I have the grubee skyhawk 66/80cc engine that I bought from bikeberry, back around three months ago. But I'm a pretty big noob, because I'm only 16 and have no clue about these engines. |
02-21-2010, 08:14 AM
| | Re: Major clutch arm problems There is a ball bearing and a rod that should be inside the sprocket.
Remove the left cover (drive side) and look up in the center of the sprocket...are they there?
02-21-2010, 11:32 AM
| | Re: Major clutch arm problems No, but I do hear a lot of rattling when I pick up the engine |
02-22-2010, 05:06 PM
| | Re: Major clutch arm problems There should be a rod, with a ball bearing behind it. They can't go inside the engine, but they can fall out if you took the cover off and were unaware that they were in there.
02-22-2010, 05:40 PM
| | Re: Major clutch arm problems Well there's my problem, is there anyway that I couldgo to like bikeberry.com and get replacemet parts, it is it maybe included in the warranty??
Reason: Forgot some information
02-23-2010, 05:02 AM
| | Re: Major clutch arm problems They should be available from any vendor, if the guy who sold you the kit doesn't have any, call around.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
