lights for your motorized bicycle?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I would be,no batteries right and working off the white wire. What kind of $ are we talking norman? Ted...
  #11 (permalink)
Old 01-28-2008, 10:25 PM
Motorized Bicycle Builder
Default Re: lights for your motorized bicycle?
Ted
  #12 (permalink)
Old 01-29-2008, 06:20 PM
Norman's Avatar
LORD VADER Moderator
NO batteries is right works off the white wire you will have to do a little work make a mount and paint the headlight which will require sanding if you want. No chrome as fiberglass will not chrome as far as I know.
  #13 (permalink)
Old 02-03-2008, 10:17 PM
Norman's Avatar
$25.00 for the small light and that includes shipping to the lower 48 states.
Rufus is tied to the work bench and knocking out a different type.
Check it out on my home page.
Lord Vader
norms-iron-works.tripod.com
  #14 (permalink)
Old 02-05-2008, 12:42 PM
Pablo's Avatar
Amsoil Dealer
I missed this part. Thanks!
http://oilslubesfilters.com/
  #15 (permalink)
Old 02-05-2008, 04:18 PM
Norman's Avatar
Here is the new headlight on my bike just a little bigger than the first one kind of gives the bike a look of the old Harley Davidson headlight.
$35.00 and that covers shipping to the lower 48 states. You can get them in unpainted, black wrinkle, red wrinkle. With or with out the switch mounted which if mounted I mold them in place if you want to mold in your own switch I'll post a show and tell. The mounting is up to you and I can show you how to make special lugs to mount your light.
  #16 (permalink)
Old 02-05-2008, 04:29 PM
CRUISER's Avatar
ADMINISTRATOR
that looks awesome. i like. nice job lord vader. can't wait to get mine
  #17 (permalink)
Old 02-05-2008, 05:43 PM
Norman's Avatar
It will be on its way by fri. (heavy breathing)
  #18 (permalink)
Old 05-16-2008, 12:04 AM
Motorized Bicycle Apprentice
hey guys try using one of those bike generated light systems. just connect the wires that would go to the little generator to the white wire on your motor. if there are any problems check your ground.
CHEAP AND EFFECTIVE
  #19 (permalink)
Old 05-16-2008, 07:34 AM
Ilikeabikea's Avatar
I don't know what bulbs those little generator lights have in them. I know Norman did lots of R & D to find out the correct bulb that would put out plenty of light and not kill the engine. Bulb choice is critical to white wire lighting. One that draws to much kills the engine and one that doesn't draw enough burns out quickly........................
http://bdconner.com
  #20 (permalink)
Old 05-31-2008, 07:42 AM
hey not sure how to start a thread on lights so here is my fix. i use a cheap dynamo/generater style front and rear on the front i replace the 6v 3 watt globe with a LED upgrade for maglight torch ($22) which is DC so i wired in a voltage converter($1) and a regulator($1) to stop flutter. the voltage draw on the LED is .05 watt so the engine starts perfect even when cold and there is no performance difference at all. its bright white, looks sweet and cheap.FYI the voltage draw on the 6v 3 watt filliment globe was .55 volt. any electronics shop will be able to sort you out with gear and show you how to wire it up. this really does solve this problem mine has been running sweet
Similar Threads
turn signals and break lights for motorized bicycles CRUISER Motor Bicycle Safety 18 05-19-2008 03:22 PM
how to use motorized bicycle forum for posting CRUISER Welcome to the World of Motorized Bicycles 1 01-19-2008 04:32 PM
tips for long motorized bicycle engine life CRUISER Bicycle Engine Kits 3 01-12-2008 06:24 PM
