Leaky Petcock...
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. If you look close at the threaded portion of the valve, you will see a crack. If not, give it ...
  #11 (permalink)
Old 09-02-2008, 05:55 PM
Pablo's Avatar
Default Re: Leaky Petcock...
If you look close at the threaded portion of the valve, you will see a crack. If not, give it a month or so. It will break off and spew fuel everywhere. Just replace the valve.
  #12 (permalink)
Old 09-02-2008, 06:11 PM
Motorized Bicycle Builder
seriously!!! the red washer??? it's like gasket material... my instructions never said what to do with it!! is that really all I have to do, teflon tape and the "magic" red washer?
  #13 (permalink)
Old 09-02-2008, 06:14 PM
Norman's Avatar
LORD VADER Moderator
You can tip the bike over onto its side and replace or repair the fuel valve if the tank isn't too full usually less than 1/2 a tank.
norms-iron-works.tripod.com
  #14 (permalink)
Old 09-02-2008, 06:15 PM
... and buy one from you? we'll see... when the time comes!
  #15 (permalink)
Old 09-02-2008, 06:28 PM
Biker Mike's Avatar
I used Teflon only on one valve and installed it without the red washer. It leaked at the tank side of the valve. I removed it, cleaned the threads, put the red washer on and placed fresh Teflon tape on the threads then re-installed the valve. Wa La!! no leak!!. Good luck.
  #16 (permalink)
Pablo's Avatar
Well if you left the red washer out - put that in. Just don't overtighten it!
  #17 (permalink)
Old 09-02-2008, 06:33 PM
Biker Mike's Avatar
Don't over tighten anything associated with these engines. heavy Torque = bad vocabulary @%^&#**&!!!
  #18 (permalink)
Old 09-02-2008, 07:22 PM
Saddletramp1200's Avatar
More tape should fix the problem. You have to much when it will not screw inside the tank. And that little red washer, My dog thought it needed Hot Sauce! If nothing works get some "Honda Bond". It will not get hard, & is gas proof. Kind of like real thick tooth paste.
No matter where you go, or what you do, there Ya' are!
  #19 (permalink)
Old 09-02-2008, 10:00 PM
Originally Posted by BlueCollarBike View Post
did you use the special red washer that comes with the kit?
cheers
Bob
Thanks Bob!!! this was the magic bullet... I installed the red washer and then put more teflon tape on and No more leaky Petcock!!! Have I mentioned how I love this forum (Room full of Experts)??? YOU GUYS ROCK!!!
Ask a question and someone has probably had the issue before and found a simple and painless fix!!
  #20 (permalink)
Old 09-03-2008, 09:12 AM
Glade it all worked Out.
Magical..???
Hum..
No i doubt it..
But if you feel its magical you may want to rub it Then ask for three wishes,
If i where you I Would use one of those wishes to stop your Leak.
The Red Washer is used in between The Fuel Valve and Fuel tank.
For the record Teflon and Liquid Gas Do not get along And will eventually fail so keep an eye on it.
There are allot of Issues Not printed in the instructions.
That's one of the reasons We have this wonderful forum
Cheers
Bob
BlueCollarBike
Advertisers
