Leaky carb? Please help.
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. So my chinese engine was starting and working well for about a week, but recently it has been difficult to ...
Old 06-11-2008, 10:41 AM
Motorized Bicycle Apprentice
Post Leaky carb? Please help.
So my chinese engine was starting and working well for about a week, but recently it has been difficult to start. I have to prime the carb, loosen the gas cap, and put the choke at about half, and then it takes about 5 tries to start. The real concerning problem is that the carb leaks gas profusely after the engine initially runs for about 5 minutes and dies. The leak comes from the black plastic part of the carb (possibly from the bottom air holes?), and it seems to leak out about 6-8 oz of gas each time. Does anyone know what's going on here? I have read the thread regarding "rebuilding a carb," and I think I may have to seal the carb with the stuff called "RTV". Any help would be appreciated.
Best,
Cycofast
Cycofast
Old 06-11-2008, 10:48 AM
misteright1_99's Avatar
Default Re: Leaky carb? Please help.
Maybe adjust the float..
Old 06-11-2008, 10:54 AM
I'm new to engines/carbs so I'm not sure what the float is. Thanks for the feedback!
Cycofast
Old 06-11-2008, 11:00 AM
fairracing31's Avatar
Yes, sound's like the float level is to high. The float determine's the amount of fuel inside the bowl of the carb. To low and the motor will starve for fuel, to high the motor will bog down with fuel or fuel will exit threw the air cleaner or the hole's as your's is.
RTV: Silicon gasket maker
Give me a few minutes, I think Norm did a awesome post on adjusting the float; need to find it.
Here are some pic's of RTV. You can pick it up at any auto parts store
leaky-carb-please-help-ptx22073003.jpg  leaky-carb-please-help-rtv_silicone_gasket_maker.jpg
Old 06-11-2008, 11:24 AM
Carburetor pictures how to install and rebuild
Post #13 Bend the folcum arm down "VERY LITTLE" It may take several adjustment's and pulling the carb on and off till you get it right. And as Norm say's BE GENTLE!!
Old 06-11-2008, 11:33 AM
Thanks, I'll give it a shot and let you know how it goes.
Cycofast
Old 06-11-2008, 12:23 PM
i think maybe the vibration from the motor, together with the thin gauge float arm may cause the arm to bend down a little over time. i have adjusted mine 2 times in almost two months time. but it has always ran pretty well. i might add that each time,(after several adjustments) i improved the condition, but never got rid of the leak completly. also ride on some bumpy tar & chip country roads, which could also cause lots of problems.
Old 06-11-2008, 09:39 PM
Norman's Avatar
LORD VADER Moderator
a fuel filter is important its the first line defence of trash getting in the floats needle/seat. a lot of leaking carb problems is due to trash in the tank getting to the carb when no filter is used.
norms-iron-works.tripod.com
  #9 (permalink)
Old 06-11-2008, 09:41 PM
Bikeguy Joe's Avatar
MODERATOR
You said it!
  #10 (permalink)
Old 06-12-2008, 12:07 AM
Regarding the fuel filter, I purchased one from a local toro engine dealer. It's basically a plastic housing with a screen inside, so I question if this was enough? Is there a better filter you recommend?
Cycofast
Advertisers
