| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Leaking leftover oil? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. My brand new *first* build is going great. I took it for a nice long test run around the block ...  |
10-19-2008, 12:22 PM
| | Motorized Bicycle Member | | Join Date: Oct 2008 Location: Harrisonburg, VA
| | Leaking leftover oil? My brand new *first* build is going great. I took it for a nice long test run around the block a few times and it seems to run smoother and smoother the more I use it.
I've noticed that right under the engine where the exhaust pipe bolts in there's black oil that seems to have leaked out. I wouldn't say it's a lot but its certainly noticeable on a shiny new engine. Is this normal? |
10-19-2008, 01:09 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: Tucson, AZ USA
| | Re: Leaking leftover oil? Unburnt oil gets exhausted through a small hole near the top of the muffler and will spray onto anything in its path. On my bike it usually drips off the back of the front fender. I also learned early on not to wear white shoes while riding. Anyway it is a normal thing with the 2-cycle bikes unless it is leaking directly from the engine. The exhaust issue is why I am switching to a long pipe!
-and-
I'm not lost, I'm exploring! |
10-19-2008, 01:24 PM
| | Re: Leaking leftover oil? Well it's leaking out from where the exhaust mounts into the engine. Maybe my gaskets need replacing? |
10-19-2008, 02:35 PM
| | Re: Leaking leftover oil? Quote:
Originally Posted by cartisdm Well it's leaking out from where the exhaust mounts into the engine. Maybe my gaskets need replacing? | I think you just answered your own question!
I always put a little silicone gasket on the exaust gaskets to keep them from leaking...  |
10-21-2008, 05:24 PM
| | Re: Leaking leftover oil? I was thinking about running to Home depot for some parts and figured I should get this leaking problem fixed while I'm there.
1. Should I replace the gaskets or just add one?
2. What would I be looking for in the store? I have an idea in my head of just a sheet of rubber or some sort where I can trace out a replica of the current gasket and cut it out.
For the second part I know what I want but not what I'm looking for, what should I use? It obviously needs to stand up to the heat of the engine/exhaust pipe |
10-21-2008, 10:48 PM
| | Re: Leaking leftover oil? The stuff you need to use ISN'T found at home depot... It's found at a auto parts store!!! |
10-22-2008, 12:33 AM
Originally Posted by VENICE BOY The stuff you need to use ISN'T found at home depot... It's found at a auto parts store!!! | In that case I'll be heading to auto zone tomorrow. What's it called? |
10-22-2008, 07:35 AM
| | Re: Leaking leftover oil? High temp gasket material.
| | Re: Leaking leftover oil? Replace it, don't use two together.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:59 PM. | | | Sponsors
