Leaking
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I absolutely love my bike but find little oil leaks annoying at times. Any suggestions on how to prevent leaks ...
Old 08-19-2008, 04:01 PM
Motorized Bicycle Apprentice
Default Leaking
I absolutely love my bike but find little oil leaks annoying at times. Any suggestions on how to prevent leaks from the air cleaner, the gas cap and the exhaust gasket.
Thanks
Old 08-19-2008, 04:08 PM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Leaking
Clean the air filter egularly, and make sure your not running too rich.
Don't over fill the tank....simple but over looked.
Make or buy a new exhaust gasket and check the nuts once a day.
Old 08-19-2008, 04:43 PM
jasonh's Avatar
Default Re: Leaking
use high-temp RTV on the intake and exhaust gaskets. Also where the carb connects to the intake manifold.
As Bikeguy said, clean air filter regularly and make sure your air/fuel ratio is correct. And check all nuts/bolts regularly.
You can get a new gasket for the gas cap if it's leaking badly. A little bit here and there is normal, as the cap has to vent for it to work.
Advertisers
