Kill switch and light question
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by nitroscope8 Wait, how is the kill switch supposed to wire up? I have both of mine rigged ...
  #11 (permalink)
Old 06-04-2008, 11:06 PM
misteright1_99's Avatar
Default Re: Kill switch and light question
Originally Posted by nitroscope8 View Post
Wait, how is the kill switch supposed to wire up? I have both of mine rigged grounding the white wire. It shuts the engine off instantly. Been doing that for years lol.
This is how I have my kill switch wired also..
  #12 (permalink)
Old 06-05-2008, 06:05 PM
Norman's Avatar
LORD VADER Moderator
there is differant ways to ground out the ignition. My advise is you better have a way to kill it on the handlebars when your in the panic mode. the colored wire off the ignition blue or green should do it use the white wire for the lights the black is the groundwire.
norms-iron-works.tripod.com
  #13 (permalink)
Old 06-05-2008, 07:21 PM
Cool. Thanks for all the advice. When I have some time and the right connectors, ill rewire everything
  #14 (permalink)
Old 06-11-2008, 07:26 PM
tinkerfinger's Avatar
I understand what you are getting at. No, you can not use both hot wires off the magneto as the + side connection, and ground on frame. The 2 hot wires are technically two different ends of the same wire that is wrapped around a coil. As the mag turns, it charges the coil, connecting the two together is a no-no.
P.S. hooking to two seperate batteries like this would double amps and voltage. doing it to a coil will not, because both wires share the same source.
If your not sure, ask a friend first!
Advertisers
