Kick stand fix for schwinn
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Here is all you have to do is drill with a #25 drill and tap with a 10-24 tap ...
Old 02-28-2008, 07:58 PM
Norman's Avatar
LORD VADER Moderator
Default Kick stand fix for schwinn
Here is all you have to do is drill with a #25 drill and tap with a 10-24 tap and insert a long 10-24 set screw with lock tite on it. The set screw will limit the amount that the kickstands leg can extend in the down position. Stock it will come all the way down and allow the bike to lean over too far and then its on its side. you can use a different size screw if you want and use a bolt or regular screw in place of the set screw.
I don't have a before picture but its stands nicely now
My finger is pointing to the screw where it sticks out on the inside of the stand and limits it travel. You can see a mark on the stands leg where the set screw has left its mark on the leg
I have an allen wrench in the set screw adjusting it to make the bike stand up better the Allen wrench is hard to see but it is there if you look closely. It looks like a black rod. the darn picture is just a little out of focus. but you get the idea.
This is an easy fix for a bike that likes to lay down all the time if your kickstand is like this one.
norms-iron-works.tripod.com
Old 02-28-2008, 08:42 PM
CRUISER's Avatar
ADMINISTRATOR
Default Re: Kick stand fix for schwinn
very nice norman. nothing worse then seeing a gust of wind knock you motorized bicycle on the ground
http://stockmarketcats.com/
Old 02-29-2008, 03:17 PM
Autocycler's Avatar
And your clutch lever snap off from the fall.....
This mod will save a lot of clutch levers from an untimely death
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
Similar Threads
My Two-Stroked Motorized Schwinn Cruiser Bean Oil Pictures and Videos 6 02-24-2008 06:58 AM
Couldn't stand it no' mo'! Bikeguy Joe The Tavern 6 02-15-2008 06:19 AM
Egors Motorized Schwinn Egor Pictures and Videos 12 02-04-2008 10:02 PM
Starting bicycle engine on center stand TeddyB Motorized Bicycle General Discussion 10 01-30-2008 06:32 PM
