Stock Market Cats Alternative Energy
Installing chain?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I need to figure out how to put my chain on. I've watched this video here Panofish Blog Motorized Bicycle ...
  1 links from elsewhere to this Post. Click to view. #1
Old 05-16-2010, 08:22 PM
Default Installing chain?
I've watched this video here Panofish Blog Motorized Bicycle – Part 2 and he shows how to punch out the chain piece and remove links. I don't have the chain punch he has but I tried it with a nail and couldn't get it punched out. Am I missing something? I didn't try too terribly hard (didn't want to break it) but it feels like it should have punched it with my force. Just have to give it some elbow grease?
I have the grubee skyhawk gt5 66/80 cc kit, if it matters. The chain that came with it looks a bit bigger than my bike chain.
Old 05-16-2010, 08:29 PM
Default Re: Installing chain?
Have you got an angle grinder or dremel?
Old 05-16-2010, 08:58 PM
I have an angle grinder. I don't have a dremel. Why?
Thanks for the help so far.
Old 05-16-2010, 09:12 PM
Long's Avatar
wal mart 6 bucks or a vise
Old 05-17-2010, 12:19 AM
Cabinfever1977's Avatar
Mark chain to be cut,Hacksaw and pliers,then use master link.
Old 05-17-2010, 12:24 AM
Banned
Why not use a chain removal tool? They're pretty cheap. Or ask around and borrow one from a friend. They're pretty common in toolboxes.
Old 05-17-2010, 02:33 AM
I use a bench grinder
But a angle grinder does the same thing
All you do is cut the tip ends off
Then get a flat srew driver tap between link then it just pops off
Or pliers
Hope this make sense This is just what i do
Old 05-17-2010, 09:49 AM
My chain came pre-assembled, completely linked together. I didn't see any master link. I can check again.
Old 05-17-2010, 10:11 AM
JTinFL's Avatar
As earlier said use a bench grinder.Take chain at the link that's needed to be taken out.Fold chain to where the rivet is sticking out.Then grind the head of the rivet flat using the side of the grinder wheel.You can take a pair of needle nose pliers and open wide enough to lay the link on top.And then take a nail or or whatever will fit to drive out the rivet you just ground flat.I've found if you grind both sides of that rivet flat,it will come out easier.
Old 05-17-2010, 03:56 PM
I used a vise and a nail punch (you could probably use a nail too if it's thick enough). No grinding required =D
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/installing-chain-18779.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 05-16-2010 10:16 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
