| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | I need a stop light, not a tail light Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. There are special switches called microswitches which are designed for this sort of thing. You can pull them out of ...  | |
07-17-2009, 06:40 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Canada
| | Re: I need a stop light, not a tail light There are special switches called microswitches which are designed for this sort of thing. You can pull them out of old microwaves, amongst other places. |
07-17-2009, 07:03 PM
| | Motorized Bicycle Senior Member | | Join Date: Jun 2009 Location: Davison, Mi
| | Re: I need a stop light, not a tail light >nashbar sells a stop tail light
For now I want to try to avoid the "n" battery. I have enough battery sizes laying around. |
07-17-2009, 10:52 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: independence missouri
| | Re: I need a stop light, not a tail light ok but mine has gone for over 6 months and it activates only when you pull the lever. You don't have to turn it on it stays off until the brake lever is pulled JMO i like mine
stay thirsty my friends
03-07-2010, 10:03 PM
| | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: Alabama
| | Re: I need a stop light, not a tail light I have seen one that works off of a spring or something. Aero07 has one. It is battery operated with no wires. When you brake, it automatically comes on. It's a tail light as well as a stop light. PM him if you can't find something. I'm sure he'll help you out if you are interested.
__________________ Caution! I give opinions as if they were worth something. Use at your own risk.
03-07-2010, 10:35 PM
| | Re: I need a stop light, not a tail light Here's one idea. I used a small micro switch mounted to a bracket and wired it to my brake light. The roller on the micro switch lever is actuated by the rear wheel brake. Simple, and it works. The switch I used is sealed so its not effected my moisture.
Over Youth and Skill |
03-07-2010, 11:22 PM
|  | a guy who makes cool bikes | | Join Date: Aug 2009 Location: orange county, ca
| | Re: I need a stop light, not a tail light i've got one of these: Wireless Bicycle Brake Light for Mountain Bikes, City Bike Carriers, and Dynamo Bicycles
it's got an accelerometer in it, so no wires. it doesn't work that great, like the brake light isn't that sensitive, it comes on when you stop or slow suddenly, but it makes me legal.
the plastic mount is absolute garbage, though. if you use it, you might as well throw 30 bucks into the street and watch it get run over by cars. |
03-07-2010, 11:31 PM
| | Motorized Bicycle Elite Member | | Join Date: Nov 2009 Location: IL
| | Re: I need a stop light, not a tail light bairdco, where'd you buy that? I can't find it for sale on the interwebs.
Edit - Oh never mind, I found them on eBay. Search fail.
03-07-2010, 11:33 PM
| | Re: I need a stop light, not a tail light paste this into the ebay search: 270473225186 |
03-08-2010, 05:16 AM
| | Motorized Bicycle Senior Member | | Join Date: Nov 2009 Location: Lakeland, FL
| | Re: I need a stop light, not a tail light If you're okay with wiring, couldn't you use a mercury switch from a household thermostat or something like that? Or, here's one that isn't in a little glass tube and you could probably solder wires right to it. http://www.parts123.com/parts123/yb....5Z5Z50000050F# | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:46 AM. | | |
