How to wire a headlight??
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. how would I go about wireing a headlight using the white wire??...
Old 07-28-2008, 05:12 PM
Motorized Bicycle Apprentice
Default How to wire a headlight??
Old 07-28-2008, 05:38 PM
Default Re: How to wire a headlight??
ya might wanna do a search using those terms, headlight and white wire
there has been a LOT of discussion about this.
Let the solution BE the revolution
Old 07-28-2008, 05:42 PM
Norman's Avatar
LORD VADER Moderator
You will need a switch so you can turn off the light, connect one wire to the bulb center and one wire to the bulbs side one wire will go to ground and the other through the switch to the white wire. If I knew how to draw on the computer I could show you better.
bulb-----------switch-------------white wire to engine
bulb-----------------------frame ground or ground the wire to the engine
norms-iron-works.tripod.com
Old 07-28-2008, 10:33 PM
thank you very much guys
Advertisers
