how much rust is too much for inside your gas tank?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. because there is plenty in mine. what should i do? ive read to use a shop vac but this just ...
LinkBack (2) Thread Tools Display Modes
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 08-11-2009, 03:07 PM
Default how much rust is too much for inside your gas tank?
because there is plenty in mine. what should i do? ive read to use a shop vac but this just seems like it would be useless. is there supposed to be a tolerable amount in there or should i try and get a replacement? any help would be much appreciated. this is my first built btw, im outside trying to slap it together as we speak!
Old 08-11-2009, 04:01 PM
Pablo's Avatar
Default Re: how much rust is too much for inside your gas tank?
If it was really nasty I would ask for a replacement. Some crust and rust is normal, and treatable. Get out as much as you can, then put a bunch of clean screws, nuts, BB's, chain, etc in the tank and shake the heck out of it. This gets most of the crusty stuff. Then spray with PB Blaster or Kroil a few times, double rinse with premix gasoline and you should be good to go.
Old 08-11-2009, 04:04 PM
HoughMade's Avatar
If it can't be made completely, 100% clean with a couple hours of diluted toilet bowl cleaner, then get a new one.
How much cancer is too much?
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 08-11-2009, 04:59 PM
i sprayed it with wd40 and used a brush to get a bit of it off. what is pb blaster and kroil exactly? any different or better than wd40? and what do you mean by premix lol im a newbie.
by diluted toilet bowl cleaner i assume you mean with water. what kind of toilet bowl cleaner would you think to use? ive been using clorox for my toilets, which im sure contains bleach, and im not sure about using that.
Old 08-11-2009, 05:51 PM
Pablo's Avatar
PB Blaster and Kroil are also spray penetrants/rust removers, in a class above WD-40. But don't knock yourself out finding them. Problem with a brush is you can't reach all the areas. Premix is fuel oil mix.
Can't comment on the toilet water. Never tried.
Old 08-11-2009, 06:48 PM
HoughMade's Avatar
I have used hydrochloric acid based toilet bowl cleaner for this exact issue- but it is a lot stronger than you think- 1/4 strength or less would probably work. It will etch the tank. After the hydrochloric acid, a wash with a phosphoric acid metal prep will prevent flash rust and help prevent re-rusting overall.
Different approaches- I'm sure Pablo's will work, I just know that I have done it this way.
Old 08-11-2009, 10:53 PM
2door's Avatar
Course sand or small pea gravel will also work. A couple of cups, shake the tank hard until your arms get tired then pour out the sand/gravel and rinse well wth hot water. Compressed air will help dry the tank after the water but make sure you get all the sand out. If you have access to a sand blaster (bead blast) that also works good but again rinse until you know the sand is all gone.
Over Youth and Skill
Old 08-12-2009, 02:25 PM
thanks everyone. im gonna give it a shot and ill let you know how it turns out
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/how-much-rust-too-much-inside-10257.html
Posted By For Type Date
Xbox 360 Red Ring of Death Errors: Facts and Myths - We Pay Cash for Your Scratched Video Games! This thread Pingback 08-17-2009 08:41 AM
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 08-11-2009 05:46 PM
