| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | How to fix broke stud/bolt Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. If you are lucky enough to have broken a stud or bolt with threads left; you can use vise grip'...  |
06-23-2008, 06:00 PM
| | How to fix broke stud/bolt If you are lucky enough to have broken a stud or bolt with threads left; you can use vise grip's, needle nose or pliers to remove stud/bolt. Thier are stud removal tool but most likely you won't have room to use....and it is a small eninvestment, if you brake alot of stud's and bolt's you may want to look into it.
Broken bolt with threads left
Use vice grip's or pliers to remove  |
06-23-2008, 06:04 PM
| | Re: How to fix broke stud/bolt If you have enough stud or threads left, you can make a slot and use a screwdriver to remove....I'm using a grinder but I have also used a hacksaw
Make slot with grinder
Slot on stud/bolt
Now you can use screwdriver  |
More to come...... |
06-23-2008, 06:11 PM
| | Re: How to fix broke stud/bolt Here is a stud removal tool, there are many different sizes and type's...this is for exsample
This only work's if you have enough stud left to grap on too
More to come.....Using screw extractor....
06-23-2008, 06:38 PM
| | Re: How to fix broke stud/bolt Okay... Now if it break's flush to were you cannot use plier's or make a slot..you can use a screw extrcator
Screw Extractor's
Tool's you will need...Drill, drill bit, center punch, hammer, cresent wrench or right sized wrench, screw extractor..
Drill bit and screw extractor
Broken stud/bolt flush break  |
06-23-2008, 06:45 PM
| | Re: How to fix broke stud/bolt Use center punch on center of stud/bolt for drilling...make's drilling much easier and helps keep drill hole in center
Next..you want to start to drill...sometimes drilling with smaller drill bit, then bigger drill bit makes it easier. Always use nice sharp drill bit's or it will take forever.. Do your best to keep the hole centered... It's good to drill hole all they way threw, but sometimes not necessary
Once you have your hole you can use the screw extractor
Now you want to turn with wrench screw extractor counter clockwise  |
06-23-2008, 06:49 PM
| | Re: How to fix broke stud/bolt With any luck it will work great
Now...If you break screw extractor in the bolt/stud you are in deep crap..Sometimes... The smaller the stud/bolt, the more difficult it will be..after a certain size, I will not use the screw extractor method
More to come when time is available.... |
06-23-2008, 08:20 PM
| | Re: How to fix broke stud/bolt |
06-23-2008, 08:53 PM
06-23-2008, 10:13 PM
| | Re: How to fix broke stud/bolt | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:51 AM. | | |
