How do you align the rear sprocket????
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I am really getting into these motorized bicycles and have been reading the posts and studying the information here and ...
Old 05-17-2008, 03:34 AM
Motorized Bicycle Builder
Default How do you align the rear sprocket????
I am really getting into these motorized bicycles and have been reading the posts and studying the information here and everything seems straightforward except one thing.
When you install the rear sprocket onto your existing wheel, I notice that it has the sprocket and another plate and some gasket-like material around the spokes. This whole thing bolts together, but how do you get the sprocket centered on the axle so it isn't out of round??
Old 05-17-2008, 05:43 AM
Bikeguy Joe's Avatar
Default Re: How do you align the rear sprocket????
Very carefully.
Old 05-17-2008, 05:46 AM
Seriously, you have to put the wheel on the bike or a stand and make an "indicator" to mark alignment and run out, then slowly, carefully tighten it.
Also, check to make sure the hole is drilled on center and if it's not "adjust it".
Having said that, I'll add that on a one bike I never could get it straight (run out 'front to rear') and the only adverse efect it had was a little more noise than normal.
Old 05-17-2008, 05:58 AM
CRUISER's Avatar
ADMINISTRATOR
i took a square and put held it on the rear triangle of the bicycle an adjusted it so it just barely touched the sprocket and spun the wheel slowly tightning the bolts to keep it all the same. so not to much wabble. i also put the square so it just barly touched the the teeth on the sprocket again i spun the whell to make sure all was square. you will never get it perfect unless really lucky but that will make it close at least. hope that made sense
Old 05-17-2008, 09:05 AM
Yes, that explains it; just a little nudge here and there. I thought there was some clever tool that aligned it all or something.
This I can do.
Old 05-17-2008, 10:48 AM
Ilikeabikea's Avatar
I clamped my rear wheel in a vice so that the sprocket was horizontal instead of vertical. It just seemed easier to do that way for me.....................
http://bdconner.com
Old 05-17-2008, 11:37 AM
misteright1_99's Avatar
I wrapped a coathanger around frame and bent it so the tip would just barely touch, spin the wheel, and tighten the 9 bolts accordingly....
Old 05-17-2008, 07:54 PM
Many ways to do it...I cut a piece of plywood so there was a slot in it that the wheel would sit in. I used a drywall screw to attach a piece of 3/4"X3/4" pine as the "alignment tool" and that way I can swing it in or out to true a wheel or align the sprocket.
Similar Threads
Rear wheel, spokes and bearings toytime Motorized Bicycle General Discussion 28 06-12-2008 10:59 PM
rear view mirrors CRUISER Motor Bicycle Safety 15 05-12-2008 05:14 AM
Chain tension wt. rear suspension jimraysr Motorized Bicycle General Discussion 4 05-10-2008 11:30 AM
Rear mount chain drive bgoates Motorized Bicycle General Discussion 7 04-13-2008 07:01 AM
Motorized Bicycle Rear Wheel RedB66 Motorized Bicycle General Discussion 1 04-03-2008 09:16 PM
