High Idle...!!!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. First off..... I'm hooked on this damn thing!! Finished my build this weekend...and took some residential cruises. My ...
Old 06-16-2008, 01:54 PM
Motorized Bicycle Apprentice
Default High Idle...!!!
First off..... I'm hooked on this damn thing!! Finished my build this weekend...and took some residential cruises. My question involves idle speed. From what I have read, the screw on the carb adjusts the idle speed. As I was cruizing at a fast idle, I was adjusting the carbs screw and it didnt seem to make any difference in speed.
Thanks guys,
Mike
Old 06-16-2008, 02:16 PM
fairracing31's Avatar
Default Re: High Idle...!!!
Welcome Mike to the forum
Yeah some of these idel screw's just don't work, I'm lucky mine work's fine. Maybe it is working but you have your throttle cable too tight and your throttle slide is not going all the way down. Adjust on top of the carb, hopefully this is what it is.
Hope this was some help
Old 06-16-2008, 02:21 PM
Thank you fairracing31....
Yeah....I have the cable end adjusted all the way down at the carb....but I was thinking the same thing about the slide not being all the way down. Could it be possible that the throttle cable is too short?
Mike
Old 06-16-2008, 02:34 PM
deacon's Avatar
I would try adjusting the cable at the top of the carb completely one way then completely the other if nothing changes then I would think you might have a cable problem. remove the cable end from the throttle handle on the bars to see if that helps if it does then you are probably right the cable could be too short.
Old 06-16-2008, 04:05 PM
RedB66's Avatar
You can also check the fitting where the cable attatches to the throttle handle. Also check for air leaks around the manifold.
Old 06-16-2008, 10:23 PM
Well guys...... I think the problem is an air leak. I had the bike (high)idling with the clutch in, while I sprayed some brake cleaner around the carb clamp... It stopped the engine dead. I think it is safe to assume that I have an air leak....eh??? So tomorrow after work.... I shall buy some rtv and do it up.
Mike
Similar Threads
How fast do these Chinese 2-strokes go. 20 mph easy at idle. spad4me Bicycle Engine Kits 12 06-08-2008 06:46 AM
High in the Emerald Triangle SmokingDog Introduce Yourself 7 05-22-2008 01:15 PM
Leif of the High Desert So Cal Leif E Grina Introduce Yourself 9 04-13-2008 10:20 PM
Loss of high RPM spark? Pablo Bicycle Engine Kits 93 03-28-2008 11:14 AM
