Help, Speedo is failing
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. My bike speedo drive sprocket seems to be on the verge of biting the dist. It no longer reads an ...
Old 07-15-2009, 08:56 PM
Pitchfork311's Avatar
Default Help, Speedo is failing
My bike speedo drive sprocket seems to be on the verge of biting the dist. It no longer reads an accurate speed, but swings the needle all over the place. The piece that runs in the spokes seems to be breaking as it has movements in the X and Y axis. Shifts up and down while rotating.
Anyone know where to get a replacement. I am also thinking about somehow mounting that piece solid to the wheel. Any Ideas?
Pick is of the assembly, the piece that moves is the gold part, its a stuert warner speedo assembly
Old 07-16-2009, 01:17 AM
Finfan's Avatar
Default Re: Help, Speedo is failing
I've never had a lot of faith in those mechanical Speedo's. I got one from Spooky Tooth once and after I back calculated the rpm scale vs. the mph scale I figured it would be accurate on a something like a 32" diameter wheel. Most bike shops will carry a wired speedometer that senses a magnet attached to the spokes for $20 - $30. The wireless ones are a lot more expensive. I recommend that you stay away from Blackburn. It was difficult to program and always had problems. I've since switched to a Cateye Velo5 and it is much simpler and so far more reliable.
-and-
I'm not lost, I'm exploring!
Old 07-16-2009, 07:21 AM
old motorbike's Avatar
Or use a small GPS
Old 07-16-2009, 07:43 AM
Norco John's Avatar
The electronics are more accurate and have no moving parts but some have reported problems with erroneous readings from interference from the sparkplug.
I have a Stewart-Warner on mine. Rockin' it Old Skool...
Old 07-16-2009, 07:55 AM
markeatmark's Avatar
don't give up on your old school speedometer. I have one from the 1972 made in france. and it still works fine. as far as accurate. how accurate do you need to be?
Old 07-16-2009, 11:14 AM
Well, I re adjusted it and mounted the sprocket to the front wheel, when riding in today, it read better than it ever has. think I got it working again. Thanks for all the ideas guys
Old 07-16-2009, 01:27 PM
Norco John's Avatar
A little Tri-Flo or moly lube down in the workin' bits on that speedo drive probably wouldn't hurt things, either.
