help motor always engaged!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I just installed the motor 80cc from Raw.The motor is always engaged. It never free wheels unless I take ...
Old 09-30-2008, 08:50 PM
Motorized Bicycle Apprentice
Question help motor always engaged!
I just installed the motor 80cc from Raw.The motor is always engaged. It never free wheels unless I take the sprocket chain off the motor. I can turn the motor with my hand and the motor is engaged though. I turn clutch handle where the cable inserts into but it does not turn on enable the wheel to turn. Is there something I did wrong out of the box. There is no chain binding etc and the motor does turn with my hand only but I cannot free pedal it????? Help Can some send a note to me at ws50599@yahoo.com
Old 09-30-2008, 09:00 PM
Saddletramp1200's Avatar
Default Re: help motor always engaged!
Ok sounds like the clutch is not dis-engaging to me. Check the slack in the cable. If it has a little slack tighten it a little. You can "feel it" dis-engage. With out more info thats the only idea I have. Welcome to our forum! Hope I helped.
No matter where you go, or what you do, there Ya' are!
Old 09-30-2008, 09:53 PM
I don't have the cable connected. It's just free wheeling as motor engaged when I try to manually engage the clutch cable the motor turns and never free wheels the clutch arm on the outside where the cable clutch wire goes only turns so far. The pin inside is suppose to be spongy right? its not, there is no play in it when I push down on the pin. Motor is always engaged.
Old 10-01-2008, 09:28 AM
Bikeguy Joe's Avatar
MODERATOR
Use some penetrating oil. Use a "cheater" tube over the arm and push it in.
There, now it pushes in, finish building the bike.
Old 10-14-2008, 09:32 PM
got it fixed took it all apart and greased the **** out of it and backed the clutch off...riding high in Iowa!
Old 10-14-2008, 11:50 PM
tyrslider's Avatar
Theres plenty of slop err uh I mean room for grease in there huh.
Advertisers
