Help! Dax shift kit, SBP BB adapter, crank has play!
OKflyboy
Okay, so I've come upon the first problem that has me truly stumped.
History:
Frame: 10 year old Target "China" special. (Essentially the 10 y/o Target equivalent of the "Roadmaster" bikes that WalMart is selling now)
Trying to install a Dax shift kit. My bike originally had a 1-piece Bottom Bracket. I purchased the 1-3 Bottom Bracket adapter from Sick Bike Parts and installed it tonight.
Here's the problem:
Once installed, the new crank from the shift kit has WAY too much play, I'd say a little under a 1/4", even if I leave just enough threads for the left side lockring to barely grab. I can take the slack out, but if I do, the bearing cup threads disappear all the way into the adapter, and I can no longer install the lockring.
Pics to follow.
Bearing cup installed enough to remove play (no threads left to install lockring):
attachment.php
Enough threads to (barely) install lockring but about 1/4" lateral play in the crank:
attachment.php
attachment.php
There are two widths of BB tubes. One requires a 68 mm bearing spacing and the other requires a 73 mm bearing spacing. Never seen a one piece with the 73 mm but there is a first for everything. What you are looking for is a 7R spindle. 134 mm wide with 73 mm bearing spacing.
After googling for a while, I came to that same conclusion, at first. But when I went to measure the BB tube to confirm, I came up with 68mm. Unless I'm measuring wrong. Its just the tube, without the adapters that I'm supposed to be measuring, right?
Like this?:
attachment.php
Or is it from the outside of the adapters? If so then I get 74mm.
Thanks for your help, Ghost. (Truth be told I'm already regretting not buying my shift kit from you guys. I've been using your instructions this whole time since Dax includes no instructions with his kits and his video instruction series appears incomplete as of yet...)
Alright, that's got to be the problem, I can't find anything else. So I went ahead and ordered the 7r crank from you guys.
Thanks!
Ara
I am sure the 7R spindle will solve your problem but I am still stumped why you have this issue in the first place. It appears that you assembled everything correctly. Dumb question I know but do you have both bearings installed and are they facing the correct direction? Just throwing out ideas.
I don't mind the question, in fact I welcome it, I'd hate to find out it was all because I missed something simple but was too proud to check. But yes I do have both bearings installed, and correctly. I double checked those too during my head scratching session last night.
I will not claim to be an expert, by any means, but I'm pretty good at being able to read about something then apply it. But like I said in my first post, this one has me stumped... Its a 68mm bracket tube, as far as I can tell, everything is installed correctly, also as far as I can tell, and yet, the crank does not fit correctly. I suppose its possible I got the wrong size crank in my kit from Dax, is there a crank shorter then 68mm? Will have to measure the crank, but I'm only on lunch right now, so it will have to wait until I get home tonight.
Thanks again, Ghost!
Got the 7R crank in the mail today. Did a quick and dirty install (no grease, etc) before work and it fit great! Now to pull it out and grease the bearings again and install it for good. Thanks again, Ghost.
Sick Bike Parts FTW!
not sure if it was just my setup or what- the left side bearing cup had become loosened just from pedaling it around the shop. i reinstalled with some loctite and tightened. just some FYI before install :D
