***help With Dax Install, Part 2***
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. well i've run into two new problems. 1) i can't understand where the throttle line is supposed to ...
Old 07-26-2008, 01:18 AM
Motorized Bicycle Builder
Default ***help With Dax Install, Part 2***
1) i can't understand where the throttle line is supposed to attach on to, the engine or the carb. i just don't see where it could go. any help here?
2) the biggest problem yet is when i was just about done and putting on the spark plug when i realize it won't clear the top of the bike frame. talk about a load of crap. so i am stuck with two options that i can think of.
a) cut from the top of the bike frame so that i have enough clearance to install the spark plug. i'm not sure if this will weaken the frame considerably or not. what do you think? i think this may be the better of my two options.
b) re-mount the engine so that i have more room to clear the top of the bike frame to insert the sparkplug. this seems like a good idea but this means i will have to drill another hole in the downpipe. also, i have already cut the chain to position and if i remount the engine i am afraid it will be to short.
so i think option a might be my best bet, but i'm going to sleep on it. let me know what you guys think. thanks again. i've attached a bunch of photos. so enjoy!! sidenote, i also cut from the bottom of the sparkplug attachment (you can see from the picture) to see if i could fit the sparkplug on but it did not help. you don't think that will hurt anything, do you? now that the sparkplug attachment is short and covers less of the sparkplug.
help-dax-install-part-2-img_7506.jpg  help-dax-install-part-2-img_7507.jpg  help-dax-install-part-2-img_7510.jpg  help-dax-install-part-2-img_7511.jpg  help-dax-install-part-2-img_7512.jpg
Old 07-26-2008, 01:20 AM
Default Re: ***help With Dax Install, Part 2***
here is another photo of the shortened sparkplug attachment cable. i hope it was ok for me to shorten it about an inch
Old 07-26-2008, 01:52 AM
fairracing31's Avatar
Dax does have a installation manual on his site...well I've got time here you go....from Dax
Remove the cap and all parts
Place needle into center of carb slide and then put flat washer with groove on top of needle making sure you have the groove lined up with the groove in the carb slide
Install cable to plastic grip, then thread this end through the carb cap and spring
Compress spring and load cable into the end of the slide.Put the entire lenght of the cable into the slide, then release the spring inside the carb slide and allowing the spring to push down the washer and holding the needle down
Old 07-26-2008, 01:53 AM
This is what it should look like when it's done...
Old 07-26-2008, 01:55 AM
for the spark plug you could try the low profile Champion CJ7Y
Old 07-26-2008, 05:47 AM
Ilikeabikea's Avatar
The pictures look like you have the carb mounted sideways. The cable needs to be on the top.................
http://www.galtx.org/
http://bdconner.com
Old 07-26-2008, 10:03 AM
nice, thanks for all the help guys. i guess i'll go to the store and get a low profile spark plug to try. as far as the carb goes, i did see those pics on his webpage, i just didn't think about it i guess i'll give you an update later.
for the spark plug will any low profile sparkplug work? i'm not too familiar with sparkplugs to know if any brand will work. thanks
Old 07-26-2008, 01:54 PM
If they do not have the Champion CJ7Y...they should be able to cross referance the Champion part number to another brand of spark plug.
Champion is the only part number that I know of the low profile....if I have time I'll look up other brand's part number's..
Advertisers
