Head gasket fit on the China 2 stroker
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Have you weasels ever noticed the head gasket on the 6Xcc Chinese chicken (zhong guo ji) engines doesn't fit ...
Old 07-08-2008, 01:24 PM
Pablo's Avatar
Default Head gasket fit on the China 2 stroker
Have you weasels ever noticed the head gasket on the 6Xcc Chinese chicken (zhong guo ji) engines doesn't fit perfectly on the studs? Is it just the bolt pattern on my engine or the gasket itself or are the new studs bent…..no actually I think the tapped holes in the block are not perfectly straight!!
As noted my aluminum gasket does not just drop on my studs, in fact it's a major PITA to get it on and off. I SHOULD have just shaved the holes just a hair larger….but it was all wet with aluminum paint so I got it on…..and then at the cylinder surface it fit well……poo poo.
Old 07-08-2008, 01:33 PM
Default Re: Head gasket fit on the China 2 stroker
hi paul, im putting my motor together today ( i hope) what thickness did you use for head gasket and what material and how did you make bolt holes? since you lapped i assumed no gasket. thanks mitch
Old 07-08-2008, 01:36 PM
Pablo's Avatar
I used the normal stock Al gasket - I got one way back when from That's dax...I should have bought a few!!
Old 07-08-2008, 03:33 PM
Bikeguy Joe's Avatar
MODERATOR
Mine drop right on.
Old 07-08-2008, 03:37 PM
Pablo's Avatar
Originally Posted by Bikeguy Joe View Post
Mine drop right on.
You Hound.
Old 07-08-2008, 03:47 PM
hi, thanks. i went to a tool rental, it has a mechanic. i showed him my gaskets, he said to reuse and if i ruin intake gasket to use manila envelope, the ex. gasket-buy gasket material at car parts, head gasket out of sheet aluminum or copper, base gasket out of cardboard. mitch
Old 07-08-2008, 08:15 PM
Pablo's Avatar
I use real gasket material with Blue RTV for my intake.
I use Mr. Gasket HD stuff for exhaust
For base I can use real gasket material. (w/RTV)
Now for the head....where are you getting the aluminum?
Advertisers
