| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Has any one else run across this one? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. The backing plates for the rag joint all over lapped by 1/8 to 1/4 inch each. I cut ...  | |
09-21-2009, 08:04 PM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: Berks Co. Pa.
| | Has any one else run across this one? The backing plates for the rag joint all over lapped by 1/8 to 1/4 inch each. I cut 2 of the joints and the 3rd joint fell into place. That is until it was assembly time. that 3rd joint overlapped again so I just followed the advice given by the seller and preyed the apart till it lay flat and went about tighten down the nuts. Well there was quite a high spot on the sprocket and as it turned out it was right over that 3rd joint.
As it turns out the whole thing has to come apart any way because there is a clearance issue with chain and tire ( flat sprocket ) so I was thinking of putting an extra piece of rubber between the out side rag joint and the sprocket. Also think I will order a Manic Mechanic sprocket adaptor latter this week.
Couple of pics to help explain.
Reason: Reformat pictures
09-21-2009, 08:53 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: wilmington nc
| | Re: Has any one else run across this one? ya, junk that rag crap and go with manic mechanic setup. I am ordering 2 of his sprocket setups this week. |
09-21-2009, 10:01 PM
|  | MANIC Mechanic | | Join Date: Sep 2008 Location: Clearwater, FL
| | Re: Has any one else run across this one? Hey guys,
The rubber mount is a bit of a hassle to install. Been there...done that! I don't like fiddling around with "ought nots"...meaning, ought not to have been done in the first place.
In terms of being fairly universal...the rubber mount wasn't, entirely, a bad idea. With enough messin' around: it is, of course, usable.
From an engineering standpoint I looked at it this way:
1) The engine is driving the rear wheel via the spokes on 1/2 of the wheel. Bad idea!
2) Based on the fixed location of the sprocket, there is little opportunity to properly align the chain with the engine. Some of the universal application criteria just became an installers nightmare!
3) Maintaining proper concentricity of the sprocket will require periodic adjustments, wheel replacement. Who needs the hassle!
The sprocket adapter addresses all of these problems, and eliminates them for good.
Jim |
09-21-2009, 10:27 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Urbandale Ia
| | Re: Has any one else run across this one? Well said Jim! I will be ordering a couple more as soon as the wheels get here so I can get them measured.
John |
09-22-2009, 12:19 AM
| | Re: Has any one else run across this one? Quote:
Originally Posted by Retmachinist Well said Jim! I will be ordering a couple more as soon as the wheels get here so I can get them measured.
John | Thank you John! Thank you tsmra & Reel Adventure!
I really appreciate your support of my shop. It means a lot to me!
Jim |
09-22-2009, 01:37 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: australia
Originally Posted by tsmra The backing plates for the rag joint all over lapped by 1/8 to 1/4 inch each. I cut 2 of the joints and the 3rd joint fell into place. That is until it was assembly time. that 3rd joint overlapped again so I just followed the advice given by the seller and preyed the apart till it lay flat and went about tighten down the nuts. Well there was quite a high spot on the sprocket and as it turned out it was right over that 3rd joint.
Couple of pics to help explain. | Dude scrap it and start again either with creative's hub adapter or start again with a new rag joint do not cut it! if they overlap pry it with a screwdriver. Also there is no need for the metal 3 peice on the other side of the sprocket as the sprocket does this job. I did the same but found that the 2 piece and the 3 peice go over each other inside the hub then the rubber pieces then the sprocket. |
09-22-2009, 08:00 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: ny,ny
As it turns out the whole thing has to come apart any way because there is a clearance issue with chain and tire ( flat sprocket ) so I was thinking of putting an extra piece of rubber between the out side rag joint and the sprocket. Also think I will order a Manic Mechanic sprocket adaptor latter this week. Couple of pics to help explain. | Out of 30 or so sprocket upgrades I had six with that issue. They happened to be the ones that came with BGF $12 36t sprockets so maybe no surprise.
It only takes a minute to get plates seated by levering them apart with screwdriver. Once flat tighten nuts equally so edges don' t pop up. Not a problem for me at all. I had much more difficulty with clamshell mounts and coaster brake installs. I also believe the rag joint type absorb shock and extend spoke life more.
The first one took a few minutes longer but the rest went quickly now that I know.
BTW where did you get those? How much and what type?
09-22-2009, 09:33 AM
| | Re: Has any one else run across this one? xlite,
Obviously you haven't had the opportunity to install one of my sprocket adapters.
I realize there are other clamshell type adapters available. I haven't tried one, so as far as I know you may be right regarding those products.
My adapter was designed for a bike that I was building for myself, that had a coaster brake hub. It was designed to drive the hub, not the spokes. It is not a hassle to install.
The idea that the rag joint absorbs shock and therefore saves the spokes is nice in theory, but doesn't hold water.
Leaving the theories aside, I don't think that anyone can argue whether or not it is a good idea to drive the entire hub.
Jim |
09-22-2009, 10:39 AM
Originally Posted by Creative Engineering Leaving the theories aside, I don't think that anyone can argue whether or not it is a good idea to drive the entire hub. | Driving the hub sounded better in theory,  but not practice in my case. Only two other bikes that ever came back with broken spokes happened to be clamshell. Those riders were pretty heavy which maybe be a factor. And I did have broken spokes myself recently with rag joint so maybe it was coiincidence.
Installation took longer but that may be because I'm getting so good at slapping on those el cheapo donuts. The real issues arose when they changed to a bike with different size hub. The clamshell did not fit. And another fellow went through several bikes before he found one that was adaptable because of hub shape, not just size.
Personally it would not work for me either because I also try many different bike models and there's a cost issue. Your product is very cool looking and I know several people who are very happy with it. IMO it depends on what people are looking to get out of these HTs. |
09-22-2009, 09:12 PM
| | Re: Has any one else run across this one? It was part of the 66CC kit I ordered. I'll refrain from stating where the kit came from. Don't want to start a bash fest, just curious how often this might come up. If I reuse the rag joint that 3rd joint will get trimmed. Honestly I just don't see how the backing pieces would have laid flat with that much over lap on each segment (1st picture in original post). Had I just trimmed that 3rd segment it would have probably turned out fine. Those little bolts got cranked down ALOT to smooth out the high spot with in ~1mm. Half stepping it again that’s all. It will be a little while before the engine gets fired, after looking in the exhaust port there is a little flash that should probably be removed. Working on 2 stroke motors is all new to me. Time to start reading up. Winter is right around the corner and I HATE the cold and snow so there is plenty of time. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:16 PM. | | | Sponsors
