| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Hand grip removal- What's your method? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. My best to date method for removing the grips is with a pair of pliers.
Of course it ruins them. ...  | |
11-21-2009, 01:58 PM
| | Hand grip removal- What's your method? My best to date method for removing the grips is with a pair of pliers.
Of course it ruins them. I have also used a punch and hammer and that is waaay less destructive, but still a little harsh on the vintage grips and some of the softer ones.
My best to date method without destroying them is to pry up the edge, (careful there with the screwdriver) shoot some windex in there and give them a couple of twists. After working them for a few seconds, they will slide off like magic.
__________________ If it ain't broke, and you mess with it long enough, it will be.
11-21-2009, 02:48 PM
| | Re: Hand grip removal- What's your method? A long skinny screwdriver, a squirt of WD-40 and some compressed air into the opposite grip. They'll pop right off. The compressed air makes it easier but it's not necessary. (oh, and don't aim the grip you're removing at anything. They tend to come off with some force)
Over Youth and Skill |
11-21-2009, 02:51 PM
| | Re: Hand grip removal- What's your method? Put a cresent wrench on the bars (not on the grip) & hit it with a hammer to hit the grip off the bars!! |
11-21-2009, 02:54 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008
| | Re: Hand grip removal- What's your method? Quote:
Originally Posted by Bikeguy Joe My best to date method for removing the grips is with a pair of pliers.
My best to date method without destroying them is to pry up the edge, (careful there with the screwdriver) shoot some windex in there and give them a couple of twists. After working them for a few seconds, they will slide off like magic. | Hold ur finger over the hole in one grip, blow air in the other grip with an air hose and it will come right off. Sometimes you have to plug the holes with a screw or your friends fingers etc. and stick your air nozzle under the edge of the grip, blow air under it and again it will slide right off. |
11-21-2009, 04:07 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: granbury
| | Re: Hand grip removal- What's your method? If I dont want them,I use a utility knife(box cutter)and cut it down the grip and tada its done....
John-John
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
11-21-2009, 04:36 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: ny,ny
| | Re: Hand grip removal- What's your method? Utility knife, pliers, crescent... LOL! I-paint appears to be the only one here with a clue! Go to a bike shop some day and see. |
11-21-2009, 04:42 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: nh
| | Re: Hand grip removal- What's your method? compressed air with a few a drops of penetrating oil, maybe piece a wire.
its only too fast if you cant stay on!
11-21-2009, 05:18 PM
| | Re: Hand grip removal- What's your method? Yesterday I had to take grips off 3 bikes (6 grips). Took less than 2 minutes. No oil or screwdriver. Plug one hole and compressed air in the other. Pop... Then hold your hand over the tube and blow in the remaining grip. Pop...
I've probably done couple hundred by now. |
11-21-2009, 06:28 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: WVa
| | Re: Hand grip removal- What's your method? if you use wd-40 you will have time getting them to stick when you put them back on, if I dont have air I use hair spray to remove and to glue them back on |
11-21-2009, 08:16 PM
Originally Posted by saulsvilleb if you use wd-40 you will have time getting them to stick when you put them back on, if I dont have air I use hair spray to remove and to glue them back on | Not true. The WD-40 will not keep the grips from holding when you reinstall them. I've done numerous sets of grips. In fact it makes reinstallation easier and holds the grips tight afterwards.
Over Youth and Skill | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:27 PM. | | |
