| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Good Throttle + cable Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. What is the best Throttle + cable and where to buy...It looks like I have a defective throttle. Thanks...  |
11-07-2009, 12:29 AM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: Howell, New Jersey
| | Good Throttle + cable What is the best Throttle + cable and where to buy...It looks like I have a defective throttle. Thanks |
11-07-2009, 12:40 AM
| | Re: Good Throttle + cable my stock throttle broke, so i got a Sik50s Billet Throttle off ebay for 30 bucks with free shipping.
i had to gorilla glue the stock grip on, but it works great, real simple, and you don't need a hole in your handlebar.
much better response, although it's a little loose.
only drawback is it doesn't have a kill switch. so i just my old busted one, took out the plastic tube, cut the plastic lock pin out, and mounted it next to the new throttle.
for me, it's only temporary. my next bike's gonna have a thumb throttle. |
11-07-2009, 12:55 AM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Farmington, MI
| | Re: Good Throttle + cable I have had good luck with a metal thumb throttle from Ebay for $12 delivered. The entire housing and innards are metal so it is not susceptible to the normal wear of the factory throttles. I made a new throttle cable for a couple of bucks following Norm's posts. An extra reflector bracket, $2 switch from Radio Shack and some black lamp wire works great as a kill switch. |
11-07-2009, 12:58 AM
| | Re: Good Throttle + cable that's the same thumby one i got. does the throttle cable adjuster screw in? mine doesn't look like it has any threads. |
11-07-2009, 01:11 AM
| | Re: Good Throttle + cable What is the advantage of a thumb throttle? It looks like akward. |
11-07-2009, 01:13 AM
| | Re: Good Throttle + cable No- I couldn't figure out what threads were on the throttle assembly and the supplier offered little help. I ended up using a dremmel to virtually remove the 'threads' on the inside of of the throttle housing to make a press fit for an adjuster screw.
Go slow and you should be fine. Adjuster screws come in two diameter sizes from local bike shops. Aim for the smaller diameter and settle for the larger if you grind too much.
Stock throttle cable is the wrong length for the thumb throttle. I followed Norms post but I think after I I hooked it up to the thumb throttle and left in a neutral position, I made the other end 49mm off from the cable housing. |
11-07-2009, 01:19 AM
| | Re: Good Throttle + cable i haven't used one on a bike yet, but have on old ATC's, and i like that your grip's not moving around. you're not constantly twisting, and you can maintain a firm hold on your bike.
in emergency situations, like running into cars, my first reaction is to clamp down on my grips, and with a twist throttle, you could still be fully on the gas.
with a thumb throttle, you'd take your thumb off, and grab onto the grip.
the first (and so far, only) time i hit a car that turned in front of me, i was still full throttle as i banked offa her car. i didn't crash, but i was still on the gas the whole time.
iit's all up to whatever feels right to you. |
11-07-2009, 01:21 AM
| | Re: Good Throttle + cable Quote:
Originally Posted by bseelbach No- I couldn't figure out what threads were on the throttle assembly and the supplier offered little help. I ended up using a dremmel to virtually remove the 'threads' on the inside of of the throttle housing to make a press fit for an adjuster screw.
yeah, that's what i figured. i'm sure i can rig it. and i've got no probs with shortening the cable. i'm using compressionless "Jagwire" brake cables now, modified to fit.
thanks for the info... |
11-07-2009, 01:25 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: granbury
Originally Posted by Kevron99 What is the advantage of a thumb throttle? It looks like akward. | I dont like the thumb throttle,wears your thumb out from pushing it on long rides....Twist is the only way to go for me....
John-John
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:15 PM. | | | Sponsors
