Hey Guys,
I would like to remove the small drive sprocket and place a washer behind it. Is this possible and if so, what is holding the sprocket on other than the visible nut? My chain is barely rubbing the tire as it comes off the bottom of the front sprocket.
By the way, I have gained alot of info from this forum and really appreciate all the post. Latest idea I got from the postings was to use a skate board wheel as a chain tensioner. I tried it and it works great. I used the original tensioner mount and just replaced the original roller assembly with a 5/16 bolt some spacers and the skate board wheel. It did take a little time to make sure it tracked right both forward and back. Adjustment was all in the vertical position of the mount which determines level of the wheel.
Now if I can just get that spacer behind the sprocket I will be a happy biker.
