Engine top end rebuild and an engine stand
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Guys I've been working all day today first on building a bicycle engine stand and taking pictures of this ...
Old 01-25-2008, 07:21 PM
Norman's Avatar
LORD VADER Moderator
Default Engine top end rebuild and an engine stand
Guys I've been working all day today first on building a bicycle engine stand and taking pictures of this then I took the bicycle engine off the bike and tore it down taking pictures and doing some mild performance things that any of you can do I was going to get wild with it but after taking it apart and seeing its a bushed rod on both ends I pussed out as this bicycle engine wouldn't last 5 minutes doing what I had in mind to do. Anyway I'll maybe start tonight on the posts but I'm still puting the engine back in the bike and almost done So when I do start the pictures could you wait until I'm done before you make any comments on this post or if you can't wait and want to ask something pm me instead ok? I'll start as soon as I get the bike going. There's I think over 30 pictures so it will take a while.
Norman
Old 01-25-2008, 07:25 PM
Administrator (aka CaribbeanCruiser)
Default Re: Engine top end rebuild and an engine stand
cool thanks norman. what is a bushed rod? sorry if dumb question but mechanic i am not
Old 01-25-2008, 08:13 PM
Norman's Avatar
A bushed rod is a rod that really tired.
I'm yankin your chain again its a rod that instead of needle bearing or roller bearing it has a brass or bronze bushing or some form of brass bronze alloy or other metal. These engines have a sorry what ever metal it is bushing and they seem to wear out on the quick side I'll need to check into a better bushing and there's another project. I'm never going to get it done,.
Old 01-25-2008, 08:14 PM
thanks norman. i am sure that is what i have. its the cheapest kit known to man lol
Old 01-25-2008, 10:04 PM
Norman's Avatar
Ater writing the opening on the board I found out my engine has bushing on both ends instead of needle bearing( I kind of figured it did) so no real hot rodding on this but we will go from off the bike to back together on the engine and that is where it will stop cause putting it all back on is only a reverse of takin it all off. I feel naughty when I say that
Old 01-25-2008, 10:13 PM
Norman's Avatar
use vice grips to work arm to help get the cable out of arm same when you go to put it in, saves your fingers.
Here is whats under the clutch arms cover a ball that alot of you loose and a short rod the ball goes in first then the rod and grease everthing before you assemble it and note the screws the long screw goes on top at the back and doubles as the front chain guard mount.
Old 01-25-2008, 10:26 PM
Norman's Avatar
master link notice the open end is pointing to the rear when you are looking at the link as chain goes to the front sprocket, Top chain run.
this is the easy way to remove the master link clip pliers are pushing the open end off or towards the front pops off the pin in the rear and to come off so easy and you will not loose it this way.
see the clip is off the rear pin
the little booger that give people fits 10-4! amen and so on.
Old 01-25-2008, 10:35 PM
Norman's Avatar
I'm going to take the ignitioncoil out and leave it hanging on the bike cause the wiring goes through the frame and I don;t want to fish it through again.next pic. is the coil hanging.
no paint under front or rear mount I think this helps to keep the engine from wearing away the paint and that would allow the mounts to come loose then you get to walk or pedal.
  #9 (permalink)
Old 01-25-2008, 10:41 PM
Norman's Avatar
engine is on the table and I'm going to sort of match the gaskets to the ports opening intake and exhaust using the dremel tool but not now next is a engine stand to make the engine easier to work on.
  #10 (permalink)
Old 01-25-2008, 10:53 PM
Norman's Avatar
using scrap tubing and some strap this is what i'm making what I didn't know is the strap is stainless sreel and I can't gas weld stainless so in the next couple of pic I figure this out and cut a different strap. I did try to arc weld but being out of pratice I burned through the tubing really badly so while cussing I made the changes.
TADA! looks like it will work and make life a little easier and its made out of scrap
