| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Engine runs kinda "lurchy" Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Thanks to everyone for the replies to my questions on the other thread, I appreciate the input. I have been &...  | |
08-14-2008, 03:59 PM
| | Master Motorized Bicycle Builder | | Join Date: Aug 2008 Location: U.S.A.
| | Engine runs kinda "lurchy" Thanks to everyone for the replies to my questions on the other thread, I appreciate the input. I have been "shaking out" the motorbike and adjusting here and there, I believe I will have it secured and properly adjusted in a year or two
I have noticed that my engine feels like it's lurching at low speed almost as if it is only firing on every other revolution, it seems to smooth out if I open the throttle more, I did fix my chain with a solid link and some light work with a dremel, and a hammer and dolly bar behind the chain so I could "peen" the little studs over, works good.. I understand that this is still a "bicycle" so I don't want to fly around at wide open throttle, putt putt, is cool with me... I live in a retirement community and alot of the people stand there with their hands on their hips wondering what the "farg" just went by.... any help on this lurching issue?... ;thanks
Bob |
08-14-2008, 04:13 PM
| | Master Motorized Bicycle Builder | | Join Date: Jul 2008 Location: Northglenn,Colorado
| | Re: Engine runs kinda "lurchy" You may need to gear down a bit by getting a larger rear sprocket. This will bring up your RPM a bit higher eliminating that lurching. It seems to me you aren't running fast at all as it is. If you have a 44 tooth in back get a 48 tooth.
Is this a China 2 stroke?
__________________ You have found the fountain of youth. Ride and forever stay young. |
08-14-2008, 10:06 PM
| | Re: Engine runs kinda "lurchy" How fast are you going when it's lurching?
Could it be "four cycling" and running rich so it IS only firing ever other stroke?
08-14-2008, 10:15 PM
| | Re: Engine runs kinda "lurchy" Thanks Large Filipino, yes it is a China 2 stroke, I think I would rather eat crushed lightbulbs than to start changing the rear sprocket 2 days after I built it.... that sprocket was a real pita...
BikeGuy Joe, I am going really slow, just a little above idle, putt putting along, I'll say probably about 5 - 8 mph. I thought maybe my chain was to slack.. so I moved the tensioner, I still can't figure out how to bend that danged muffler pipe out of the way of my left pedal crank, I tried bending it in a vise ,even heated it with a propane torch... that sucker is hard to move at all..... any suggestions?
Thanks
Bob |
08-14-2008, 10:36 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Engine runs kinda "lurchy" Quote:
Originally Posted by Nomad Thanks Large Filipino, yes it is a China 2 stroke, I think I would rather eat crushed lightbulbs than to start changing the rear sprocket 2 days after I built it.... that sprocket was a real pita...
Thanks
Bob | Mine was the same way. I dont want to go fast. I put on a 50t and I love it, top end is about 22mph, but I can ride at idle now. I bent my exhaust (when I had it) by bolting it to the workbench, heating it up at the bend (red hot) and pulling it to where I needed it.... |
08-14-2008, 11:11 PM
| | Re: Engine runs kinda "lurchy" Well thanks gentlemen, that looks like a consensus to me. I will look into getting a bigger sprocket, but I gotta run it around for a week or three.
Thanks
Bob |
08-14-2008, 11:34 PM
| | Re: Engine runs kinda "lurchy" porting the exhaust helped the lower speed/rpm smoothness a little. but going below 10 mph impedes the minimum rpm for 2 cycle operation because my idle is higher operation than what I'm asking it for. seems you are looking for the centrifugal clutch feeling found in those automatic moped thingys I see around. feather the clutch, or pulling it in and pedal-nothing about these little fireboxes want to go slow.
El Metodo: La Improvisacion
El Objectivo: Explorar un continente que solo conocen por los libros
El Equipo: La Poderosa
El Che
Let the Solution BE the Revolution
08-15-2008, 12:13 AM
Originally Posted by pedalpower porting the exhaust helped the lower speed/rpm smoothness a little. but going below 10 mph impedes the minimum rpm for 2 cycle operation because my idle is higher operation than what I'm asking it for. seems you are looking for the centrifugal clutch feeling found in those automatic moped thingys I see around. feather the clutch, or pulling it in and pedal-nothing about these little fireboxes want to go slow. | Hi and thanks Pedalpower, I will trim the exaust gasket before I put the muffler back on.... I like the last line, "nothing about these little fireboxes wants to go slow"  |
08-15-2008, 07:44 AM
| | Re: Engine runs kinda "lurchy" I would think 5-8 is a little slow for the stock sprocket!
Yes, order a 48-50T and you'll smile again.
08-15-2008, 10:39 AM
| | Re: Engine runs kinda "lurchy" I know there's a consensus as far as using a boost bottle but it made my china engine run smooth down at the low end. Maybe you can give it a try. Boost Bottle Industries
I got the 63 to 65cc to compensate for the tube.
__________________ You have found the fountain of youth. Ride and forever stay young. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:44 AM. | | |
