engine oil???
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hey guys. I was looking at the specs the company from china that makes the Zbox engine gives us and ...
Old 02-18-2009, 06:37 AM
brisbane_boy's Avatar
Default engine oil???
Hey guys. I was looking at the specs the company from china that makes the Zbox engine gives us and i found this.
It says "Lubricating oil Two-stroke machine oil (or 10W/40, 10W/30 machine oil)"
Does this mean we can use normal 10w40 car engine oil and put it into the bottem end of the engine?
has anybody tryed this does it work??
This is what the website says.
http://www.zbox.com.au/faygo-union-kit.pdf
who needs a car wen u can have a motor bicycle
Old 02-18-2009, 07:01 AM
Pablo's Avatar
Default Re: engine oil???
No.No.
In an extreme inland China emergency maybe. But used designed 2 stroke oil.
Motor oil has far too much ash (unburnable additives) for 2 stroke usage.
Old 02-18-2009, 07:03 AM
No pablo i actully mean putting the oil into the bottem end of the engine. under the piston??
Yer i woudent use it in my fuel.
Thanks
Old 02-18-2009, 07:16 AM
Pablo's Avatar
Not a good thing either....actually worse.....you do know the case gets lube from the inducted fuel/oil....if you added motor oil to the case it would be scavenged as well.
Old 02-18-2009, 09:55 AM
Bikeguy Joe's Avatar
It will blow the seals out at best. It may hydraulic and ruin the cases or worse. Don't do it.
Old 02-18-2009, 11:39 AM
jasonh's Avatar
This will probably help explain why dumping oil in the case won't work:
A two-stroke
Just use a good quality synthetic 2-stroke oil formulated for air-cooled motors and you'll be good.
Old 02-18-2009, 03:50 PM
Thanks for the info pablo joe and jason. I wasent to sure how eveything was keeped lubed but i get it more now.
Thanks for the info and the warning.
Old 02-20-2009, 09:48 AM
I do put a teaspoon of oil into the crankcase of the engines before I start them. I use, 2 stroke oil and not car engine oil.
