Engine mounting help
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. On every manual i read it shows to mount the engine to a t-shaped mount or welding brackets. Cant ...
Old 07-30-2008, 12:13 AM
Motorized Bicycle Builder
Question Engine mounting help
On every manual i read it shows to mount the engine to a t-shaped mount or welding brackets. Cant i just mount the engine to the v-frame using the mounts made on the engine, 80cc engine btw
Old 07-30-2008, 12:36 AM
Default Re: Engine mounting help
Howdy RnalecZ
I mounted mine direct to the frame using the engine mouts supplied, but I also placed a peice of inner tyre tube around the frame, this was to surpress vibration and ensure a more secure clamping grip to the frame, these other alternative mounting methods are usually to assist for over size frame styles, if you use the t shaped mount it will make your engine sit higher in the v frame, and this could cause other issue with fitment, see how you go, Im sure other memebers will leave posts for you
Cheers
Old 07-30-2008, 01:21 AM
ebmvegan's Avatar
What bike are you going to mount the motor to?
There is no moment like the now moment.
Advertisers
