Engine bogging down
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I have a 48cc motor on my bike two weeks old, way past break in period. The top speed was ...
Old 03-30-2009, 07:49 PM
Default Engine bogging down
I have a 48cc motor on my bike two weeks old, way past break in period. The top speed was at 30mph. I was riding it last night at full throttle off and on for about twenty minutes. During the end of that twenty minutes it started to bog down, and struggle. I rode it again today and for the first 5min it ran fine, but then bogged down again. It gets to 20mph but at full throttle, and then slows down to 16mph. The throttle will be completely down and nothing happens. It will run at 16mph will it slows down and pick back up again to 20mph, and this will repeat. When the clutch is in the throttle revs fine, but in gear it struggles. After a cool down the engine runs again fine for a few minutes then bogs down again. Any help, I don't know much at all about engines. Also if it matters at all the mix ratio has been at 16:1.
Old 03-30-2009, 08:03 PM
Default Re: Engine bogging down
this is the same thing that is happening to me please help....also i feel like the engine is starving for more fuel any help is appreciated
Old 03-30-2009, 08:09 PM
MB-Monkey's Avatar
your mixture is off mix a batch of fuel at 24:1 conventional oil get a new spark plug and see what happens i bet it will start acting better
Ride it like you stole it!
Schwinn Jaguar 26" Beach Cruiser
49cc Dax
Jaguar Install Kit Manic Mechanic
Sick Bike Parts Head Gasket, Plug Wire, NGK Spark Plug
Thanks to Hiker472 for the Avatar.
HT Assembly Process
http://www.youtube.com/watch?v=U6ZfkS20oYI
HT motor testing
http://www.youtube.com/watch?v=p8Ycvad7NN4
The Amazing Wuggie
http://www.youtube.com/watch?v=hYznGdTfiR4
http://motorbicycling.com/f3/install...html#post77935
Old 03-30-2009, 08:11 PM
Creative Engineering's Avatar
MANIC Mechanic
Hey guys,
I did a thread awhile back on assembly defects.
Assembly defects
These engines are very simple...If it's loosing that much power, there is something wrong that will only get worse.
Dpending on who you bought it from, you may have no recourse other than to tear it down and fix it yourself.
Jim
Old 03-30-2009, 08:17 PM
Finfan's Avatar
Do you have a fuel filter? Try checking that it could be gummed up from a new tank. Also open up the carb and spray it out with some carb cleaner. It sounds like you are either not getting enough fuel or enough air. Make sure the choke is functioning properly also.
-and-
I'm not lost, I'm exploring!
Old 03-30-2009, 08:22 PM
Will try new mixture and spark plug. No fuel filter. engine has a 6mo warranty from gasbike.net. will be back in 30 minutes after trying new mixture.
Old 03-30-2009, 08:23 PM
well now tht you metion the choke i cannot start the engine with the choke down and when i start it up with the choke up when i put it down the engine shuts off. as you probally already noticed im new to bike engines and motors. i have narrowed it down to a couple possible reasons 1)not enough fuel 2) not enough air 3) mixtues wrong please help!!!
thanks
Old 03-30-2009, 08:29 PM
Cleaned out carb last night before I ran it for 20 minutes, thats when it ran its best until it started to bog down for the first time.
  #9 (permalink)
Old 03-30-2009, 08:32 PM
thanks
  #10 (permalink)
Old 03-30-2009, 08:41 PM
MANIC Mechanic
MB & Fin are right!
Check out the simple stuff first!
I've had so many of these apart that I have lost sight of the trees while looking at the forrest.
Hopefully it will be something that can be fixed easily. 99% of the time, it is something simple.
Jim
