| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Disc Brakes... Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello, I am thinking of putting my new engine into this bike>
Giant Bicycles - Tran Send LX (2008)
But ...  | |
08-06-2008, 12:26 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2008
| | Disc Brakes... Hello, I am thinking of putting my new engine into this bike> Giant Bicycles - Tran Send LX (2008)
But I dont know if I could since it has disc brake F & B. Do you think it will work?
I say thanks in advance :] |
08-06-2008, 12:30 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Disc Brakes... You have a couple options.
1. You could get the sickbikeparts shifter kit and keep your rear disc brake.
2. King's Sales & Service can make you a left-side sprocket that bolts to your disc brake mount. No sandwiching the spokes, but you lose your disc brake in the back. |
08-06-2008, 12:33 PM
| | Re: Disc Brakes... Ok, hmm i'm new to this stuff so....
Could I get a link to both of them? |
08-06-2008, 12:47 PM
| | Motorized Bicycle Elite Member | | Join Date: Jan 2008 Location: Orange County, CA
| | Re: Disc Brakes... Quote:
Originally Posted by ~macaddict~ Ok, hmm i'm new to this stuff so....
Could I get a link to both of them? | Both are sponsers of this site look to the bar on the left of this page both are located there
ocscully |
08-06-2008, 12:59 PM
| | Re: Disc Brakes... Ok, thanks. One last question. But if I remove the back brake can't I just install the stock sproket on there with no issues, or do I have to go with one of those two options? |
08-06-2008, 01:33 PM
| | Re: Disc Brakes... you should be able to install the stock sprocket on there no problems I think.
If you don't go with a shifter kit, I would highly recommend putting some type of brake on the back. Front only is baaaad. |
08-06-2008, 01:46 PM
Originally Posted by jasonh you should be able to install the stock sprocket on there no problems I think.
If you don't go with a shifter kit, I would highly recommend putting some type of brake on the back. Front only is baaaad. | ok, so if i remove the disk brake on the back and leave the one in the front BUT put a V brake on the back that'll work. No need for the left sided sprocket or the shifter kit. |
08-06-2008, 01:54 PM
| | Re: Disc Brakes... Well the stock sprocket is a left-side sprocket
it's just King's will give you a sprocket that mounts to the disc brake mount instead of attaching via sandwiching the spokes.
And yeah, I think a V brake would be just dandy on the rear. Never had disc brakes, but the V brakes are my fav out of the rest. |
08-06-2008, 02:00 PM
| | Re: Disc Brakes... Ok, cause I wanted to use one with disc brakes cause I have heard that using v brakes with a motor with run the brakes down really fast. If they don't really run down like they day they do, might as well just use a bike with F & R v brakes.  |
08-06-2008, 02:10 PM
| | Re: Disc Brakes... The brakes being worn down quickly is due to stopping from higher speeds. I don't think it's anything about V brakes in particular.
Disc brakes will be safer because you will have more stopping power. Something you're going to want when doing 25-30mph. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:11 AM. | | |
