| Sponsors
| | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Disabling coaster brake Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I want to run linear pulls for the front and rear. Is there a way to remove the inner shoes ...  | |
08-03-2008, 06:45 AM
| | Motorized Bicycle Apprentice | | Join Date: Jun 2008 Location: El Paso, Texas
| | Disabling coaster brake I want to run linear pulls for the front and rear. Is there a way to remove the inner shoes so I can avoid any lockup problems ?? Will this work ?? TIA |
08-03-2008, 07:59 AM
| | Re: Disabling coaster brake Yes, just take them out.
08-03-2008, 08:00 AM
| | Re: Disabling coaster brake Why not leave them in and run triple brakes?
08-03-2008, 12:16 PM
| | Re: Disabling coaster brake Well, I'm just trying to eliminate potential problems and I had read some people have experienced lockups , so ............ Is it " just remove the shoes or do I need to replace them with spacers ? Thanks for the reply |
08-03-2008, 12:28 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice Beach, CA.
| | Re: Disabling coaster brake The only times I have ever had the coaster brakes lock up, was when it was the only brake on the bike!
If you just add a good front brake to your bike & use that a little more than the coaster, you should be just fine! |
08-04-2008, 03:06 PM
|  | Master Motorized Bicycle Builder | | Join Date: Apr 2008 Location: Valparaiso, IN
| | Re: Disabling coaster brake I run a coaster brake (not the only brake) and it works fine. Repack it with high-temp grease and make sure it is repacked every so often (as you would have to with any bearings) and it will be fine. |
08-04-2008, 04:34 PM
| | Re: Disabling coaster brake I have coaster brakes on all my bikes and the only time ever had problems with them is when I try to lube them. I usually ruin them. I can do the bearing no sweat but if I fool around with the brakes its trashcan city for the wheel. |
08-04-2008, 06:56 PM
| | Master Motorized Bicycle Builder | | Join Date: Jul 2008 Location: Northglenn,Colorado
| | Re: Disabling coaster brake Three washers did the trick for me. The washers are important. Bring an axle washer from your wheel to the hardware store and match it up. Try not to get them so thick so you can adjust them out. This will work for other brands too including the China Coasters. Suntour Freecoaster/Coaster brake
__________________ You have found the fountain of youth. Ride and forever stay young. |
08-05-2008, 12:49 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: Disabling coaster brake I just removed the 2 metal brake shoes on the coaster I used...put 1500-2000 miles on that wheel before the frame cracked and I had to change bikes
Bill (aka azbill, aka azkronic)
yesterday is history,
tomorrow is a mystery,
but today is a gift...
that's why it's called "the PRESENT" |
08-05-2008, 12:53 PM
| | Re: Disabling coaster brake I have removed the shoes with no washers or spacers.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:36 PM. | | |
