| | DAX 50cc Won't Start Now, Pedals Easier Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello fellow moterized bikers.
I just bought an assembled DAX 50cc Skyliner. It started fine when I bought it, and ...  |
05-15-2008, 03:51 PM
|  | Motorized Bicycle Apprentice | | Join Date: May 2008
| | DAX 50cc Won't Start Now, Pedals Easier Hello fellow moterized bikers.
I just bought an assembled DAX 50cc Skyliner. It started fine when I bought it, and the prior owner said that it was new. While new, the bike would either start or I would not be able to peddle it after popping the clutch.
I drove the bike several times, and on the "final tour", I drove it 50 miles (used about 1/3 gallon of gas). During the final tour, I had some difficulty restarting while the emngine was warm. Now, days after the final tour, I cannot start the engine.
I did everything that was mentioned in the other letters. I verified spark, disabled the kill switch, and the engine is getting gas, as proven by the "drips" comming from the tailpipe.
I used the tickler, and after tickling, gas leaked out of the button until I manually pulled the button back-out. I removed the plug, and pedeled the gas out of the engine, and tried to restart, and it just doesn't fire-up.
I'll bet that either the engine is being flooded, or I've lost compression somewhere, hopefully on a gasket. Should I be able to pedal a broken-in engine that is fully engaged? (By the way, the engine purred like a kitten while tI peddled with the spark plug out. It gave me happy memories of what the engine should have sounded like while firing.)
I have an old compression tester laying around somewhere. Have I lost compression, am I flooding, or whatelse could be happening?
If I lost too much compression, would it be easy for me to rebuild? |
05-15-2008, 04:49 PM
| | Re: DAX 50cc Won't Start Now, Pedals Easier Try a new plug first. then varify that you have spark. Clear out the engine and then try the starting proceedure from the top, no tickler this time, just half choke. Let us know how it goes.
You could snug the head bolts down a little 25 ft. lbs. max.
05-15-2008, 04:50 PM
| | Re: DAX 50cc Won't Start Now, Pedals Easier A set of rings are easy and cheap if you are having compression problems, but you shoud need them for a few thousand miles.
05-15-2008, 05:04 PM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | Re: DAX 50cc Won't Start Now, Pedals Easier So you are 100% sure the clutch isn't slipping?
You say it pedals easier…... |
05-15-2008, 05:14 PM
| | Re: DAX 50cc Won't Start Now, Pedals Easier Let me try to understand by telling you what my bike does. I pedal it to about six or seven mph then drop the clutch it feels like it's running it sounds like its running for a couple of seconds then it starts.
So when you drop you clutch does it sound almost like it is running. If it doesn't your clutch is likely slipping. If it does then it is mostly not compression problems. spark, gas, air would be my guess.
Do you have the old plug and wire from the kit, if so I would give a new plug and wire a shot first. If it is getting gas then it isn't the fuel filter or the carb setting or it wouldn't have run in the first place. |
05-15-2008, 05:20 PM
| | Re: DAX 50cc Won't Start Now, Pedals Easier Also, if you have a blown base or head gasket, you will have little compression, both are easy to check.
Keep us posted as to what you find.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:24 PM. |
