Cutting bike/motorcycle cables....
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Silly question/poll… What tool do you guys use to cut bike brake/clutch cable neatly? Any tips? Also, where ...
Old 04-15-2008, 10:02 AM
Pablo's Avatar
Amsoil Dealer
Default Cutting bike/motorcycle cables....
Also, where did you find the little cable end caps to prevent fraying?
I've had moderate success with taping (to prevent fray) then cutting with HD wire cutters, but it ruins the cutters and smashes the cable.
http://oilslubesfilters.com/
Old 04-15-2008, 10:15 AM
nogoodnic's Avatar
Default Re: Cutting bike/motorcycle cables....
The end caps can be found at your LBS, mine gave me a handful for free. As for cutting cable, I have a good set of dykes that work on the cable itself. My problem is cutting the housing, any suggestions?...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 04-15-2008, 10:30 AM
VENICE BOY's Avatar
Custom Builder / Dealer
Use a DREMEL TOOL w/a thin cut-off wheel to cut both cable & housing!
You can also put a dab of solder on the cable end to keep it from fraying...
Check out www.VeniceMotorBikes.com
Pablo's Avatar
Amsoil Dealer
Thanks. I cut my housings with a mototool and a rotary disc cutter. Whizzes right through, nice and square. Burr free, but always check for burrs.
Old 04-15-2008, 10:32 AM
Pablo's Avatar
Amsoil Dealer
Originally Posted by VENICE BOY View Post
DREMEL TOOL w/a thin cut-off wheel!
You cut your cable with the Dremel? I was afraid it would fray it.
nogoodnic's Avatar
Cool, thanks guys...Kelly
Old 04-15-2008, 10:35 AM
VENICE BOY's Avatar
If you still have problems with fraying, solder the area you're going to cut first, then cut.
Old 04-15-2008, 10:50 PM
Motorized Bicycle Apprentice
I don't know what they're called but park tool makes cable cutters... we use them at the bike shop I work at.
  #9 (permalink)
Old 04-16-2008, 06:55 AM
Bikeguy Joe's Avatar
The best way!
In a pinch, you can use a bench grinder.
  #10 (permalink)
Old 04-16-2008, 09:13 AM
Pablo's Avatar
Amsoil Dealer
Nice - thanks guys. "You da best!!"
Similar Threads
Early Indian Motorcycle? Howard Pictures and Videos 9 03-17-2008 04:29 PM
