crank question
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. alright i need a quick tip on removing the crank from the casing.i have the block apart and would ...
Old 07-13-2009, 09:58 PM
Default crank question
alright i need a quick tip on removing the crank from the casing.i have the block apart and would like to have the crank out to take it to my machine shop to get a quote on a balance.
im stumped on this one thanks for any info you can provide ......
oh and if there is a better quality rod and piston avaliable let me know i cant find a thing.
Old 07-13-2009, 10:12 PM
Creative Engineering's Avatar
MANIC Mechanic
Default Re: crank question
If you have everything removed...MAG magnet, small crank gear, and all case screws...just tap it apart with a plastic deadblow hammer. The bearings are not a press fit to the crank.
If you have not removed the clutch assembly...you will need to! There are 3 case screws behind the clutch assembly.
Jim
Old 07-13-2009, 10:27 PM
yeah the motor is apart and i tried tapping the shaft with the small gear on the clutch side and no movement at all. it seems like there is something clipped in side or maybe a pin of some sort.
Old 07-14-2009, 12:52 AM
fairracing31's Avatar
bicycle engine total tear down
Old 07-14-2009, 09:27 AM
yup thats where im at,but i dont see anything about removing the crank only the clutch shaft.so i guess i do have to hammer it out.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/crank-question-9590.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 07-14-2009 03:18 AM
