| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Crack in Carb Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Can i use the bike with this crack?
The Engine is stalling when idling, otherwise it drives ok....  | |
06-27-2008, 05:51 AM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Montreal, Canada
| | Crack in Carb Can i use the bike with this crack?
The Engine is stalling when idling, otherwise it drives ok. |
06-27-2008, 06:38 AM
|  | Moderator | | Join Date: Dec 2007 Location: Gainesville, FL
| | Re: Crack in Carb I say "If it runs and you need it......Ride it!!". I would look into replacing that part though.
__________________ |
06-27-2008, 07:09 AM
| | Re: Crack in Carb yea but it this a source of a vapor leak? |
06-27-2008, 07:15 AM
| | Re: Crack in Carb I have just one thing to say young man..... JB weld |
06-27-2008, 08:26 AM
| | Re: Crack in Carb Yes, JB Weld, RTV sealer or even some Seal-All to fix that for now....yeah, that's your air leak.
06-27-2008, 09:23 AM
| | Re: Crack in Carb Well I am not using it today, I am already at work.
I will try to seal it up this weekend how long will JB weld hold?
I geuss I need a new carb. question of who to order from?
06-27-2008, 09:48 AM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Crack in Carb I'll third the JB Weld suggestion.
If the surface is nice and clean, the JB Weld should last quite some time.
You can get a new carb for $22 from Dax. Honestly though I'd look into finding a better carb for replacement.... ENGINE_KIT_PARTS_PAGE_2 |
06-27-2008, 09:59 AM
| | Re: Crack in Carb I better one did comes to mind but Who, what, and were  |
06-27-2008, 10:01 AM
|  | HS Math Teacher | | Join Date: Jun 2008 Location: arkansas
| | Re: Crack in Carb jb weld will hold FOREVER! that is your best bet...I've already used some of that on my clutch pin cover. it gets lots of vibration and heat, and is solid as a rock! |
06-27-2008, 10:04 AM
| | Re: Crack in Carb Forever is long time, not a big fan of vapour leaks!  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:38 AM. | | |
