Continuing use as a bicycle
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Yes, the engine chain. Just loosen the tensioner pulley and let it slide down a little until you have enough ...
  #11 (permalink)
Old 05-14-2008, 07:03 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Continuing use as a bicycle
Yes, the engine chain. Just loosen the tensioner pulley and let it slide down a little until you have enough slack in the chain. Tighten it back up and you should be good to go.
  #12 (permalink)
Old 05-14-2008, 07:05 AM
MODERATOR
When the chain is run too tight, it can quickly wear the wheel and output shaft bearings, front and rear sprockets and the chain itself. It can ruin the tensioner pretty quick too.
  #13 (permalink)
Old 05-14-2008, 10:35 AM
bgoates's Avatar
I carry a velcro strap to hold the clutch in if I need or want to ride without the motor.
  #14 (permalink)
Old 05-14-2008, 12:10 PM
Ilikeabikea's Avatar
I keep my clutch adjusted so when it is pinned it doesn't drag.....................
http://www.galtx.org/
http://bdconner.com
  #15 (permalink)
Old 05-14-2008, 03:33 PM
Pablo's Avatar
Aren't the pedals just to help start the engine
It's not as fun without the engine, but it's better for the gut.
  #16 (permalink)
Old 05-14-2008, 03:39 PM
Motorized Bicycle Apprentice
yeah, and the gut reduction was the reason i got the bike in the first place.
  #17 (permalink)
Old 05-14-2008, 04:21 PM
how did you adjust it? i was looking at it and i couldn't figure what to do to fix the problem. sorry i clearly have little to no knowledge of bicycle mechanics.
  #18 (permalink)
Old 05-15-2008, 01:50 PM
You just turn the bolt and loosen it then move it down and tighten it up again. The other side my have a screw driver slot.
  #19 (permalink)
Old 05-15-2008, 03:31 PM
Here's a thread Norman did on adjusting the clutch.....................
motor bicycle clutch
http://bdconner.com
  #20 (permalink)
Old 05-15-2008, 07:33 PM
ok, i read through it and it makes little to no sense to me. you can tell i'm not a grease monkey, i just don't understand a lot of the lingo. (loctite???) (sorry, i know i'm dumb) anyway. it just seems like if i dont do it right then i will mess it up.
also, i just got back from a ride and i put the clutch lock on started to push it up to my door like usual. it seems that something has happened to create an even larger drag. now the clutch lock does nothing and the bike wont move unless i hold the clutch all the way in. whats the deal???
Advertisers
