| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Compression after 9 Months Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Howdy Mates, Its been awhile.
I have had this 80cc running now for about 9 Months, and put a few ...  | |
03-31-2009, 03:39 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2008
| | Compression after 9 Months Howdy Mates, Its been awhile.
I have had this 80cc running now for about 9 Months, and put a few miles on it a week,
to give you an idea, I doubt that I have used more than 7 gallons of gas, but recently
noticed, it runs OK, but it seems a little harder to kick off, meaning, . . It used to pop off easily
and start right up, however now it doesn't fire on the the first try, after a hardy pedaling,
it fires and starts up. Has the compression changed that much or should I start checking
further? |
03-31-2009, 03:54 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: Compression after 9 Months is the gas mix old ?
2stroke mix gets stale pretty quickly (within 2 weeks, I think)
check you plug as well ...might be fouled
mine has a little under 4k on it and takes forever to start now
(I should shoot it and put it out of it's misery, but I need it till my new drivetrain comes in)
03-31-2009, 03:58 PM
| | Re: Compression after 9 Months I guess it could be as much as two weeks, but that would be about it.
I'll try to spray some start up fluid into it next time to see if it will kick
faster and easier. |
03-31-2009, 05:35 PM
| | Re: Compression after 9 Months Sounds like a tired plug? What plug? How old? |
03-31-2009, 06:42 PM
| | Re: Compression after 9 Months Hi Pablo,
It's an AGK B6HS, its been in for 7 Months, and is pretty well carbon coated, but not really caked. Whatya think ? |
03-31-2009, 07:09 PM
| | Re: Compression after 9 Months NGK right? I would change plugs. Low cost, simple things first. |
04-01-2009, 10:59 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Sydney
| | Re: Compression after 9 Months I had some similar probs, and found the muffler was chocker blocked with carbon.. cleaned it right up and it fired up right away and the power was back up again. Hope this helps.
"....dunno what I did to my engine the other day but now my rear tyre wears out real quickly..." |
04-01-2009, 11:15 PM
| | Re: Compression after 9 Months OK, Thanks I'll get on it, . .
It more than likely is one of the two of those, The things is with most start up even if it needs another try, you can here the compression stroke exhausting, But on the occasion I am getting nothing but a slow gruel to a hard pedal stop, I do not hear the compression escaping.
I'm not sure exactly what to think about that, . .?
Is that do to the fact that a burn combustion is pushing out the exhaust valve with enough pressure that it is causing the sound of exhaust escape?
If so, I guess then a clogged muffler would have similar results,
I think you guys know your 2 strokes.
I'll let you know. |
04-01-2009, 11:49 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Albuquerque
| | Re: Compression after 9 Months Does it have power after warming it up? Mine was pretty wore out for compression at 5000 miles when It finally just didn't have power but it would start right up! Maybe spark dunno. I saw old gas give these CH a bad attitude. |
04-02-2009, 12:23 AM
| | Re: Compression after 9 Months Quote:
I'll let you know. | Most likely. I found with mine when I opened full throttle at idle, it would rev extremely slowly at first but once it hit that higher rev, it would shoot right up meaning that there was enough pressure to escape out of the engine.
"....dunno what I did to my engine the other day but now my rear tyre wears out real quickly..." | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 01:31 AM. | | |
