Coaster Brakes
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Just came accross Sheldon Brownes pros and cons of coaster brakes. I think it bears repeating here as so many ...
Old 08-15-2009, 03:14 AM
tyrslider's Avatar
Default Coaster Brakes
Just came accross Sheldon Brownes pros and cons of coaster brakes. I think it bears repeating here as so many people, I suspect, are uninformed about them.
Pro:
Coaster brakes are unaffected by weather. They work just as well in the rain as they do in dry conditions.
Coaster brakes generally require less maintenance than any other type of brake.
There are no cables running from the handlebars, giving a tidy and simple appearance.
The lack of cables is particualrly advantageous for folding or take-apart bikes.
Coaster brakes can be a good choice for handicapped riders who lack sufficient hand strength, or for arm amputees.
Coaster brakes are usually quite narrow, fit in 110-114 mm spacing , though they can be fitted to frames with wider spacing by adding washers along the axle.
Con:
Coaster brakes make it awkward to get started up, since there's no easy way to rotate the pedals to a good starting position.
Coaster brakes often cause skidding, resulting in excessive tire wear.
When coaster brakes fail (usually the result of chain breakage or derailment) they fail suddenly and completely.
Coaster brakes are prone to overheating and fading when used in mountainous areas.
Too many bikes are equipped with only a coaster brake, so there's no back-up system available in the event of brake failure.
To be safe, any bicycle needs a front brake and some sort of secondary backup braking system.
here's the link if you want to read it all.
Bicycle Coaster Brakes
Motorized Bicycles and Accessories for the Real World!
FireBellyCycles.com
http://www.facebook.com/profile.php?...belly%2Ccycles
Old 08-16-2009, 03:01 AM
Default Re: Coaster Brakes
Nice, its easy to forget about coaster brakes these days. You hardly ever even see them anymore, except on kids bikes. They do work as well in the rain as they do any other time, which is by far their best trait, IMO. Then again, I rarely ride in the rain, so maybe it isn't that big of a deal.
Robert
The best solar, wind, EV, and alt energy forum on Earth
This space under construction, which may be why I'm half a bubble off plumb.
Old 08-16-2009, 06:27 AM
yeah i have a huffy beach cruiser with a coaster brake i really like it some time in the future i will put a front brake
Old 08-16-2009, 06:47 AM
BarelyAWake's Avatar
Hmm... in my ignorance I just assumed that coaster brakes would be the LAST choice for a MB given the inability to backpedal, I even thought they could be dangerous.
Of course that was before I joined this forum and saw just how many have them.
So - how much are they an issue with MBs? Do y'all like them? There's any number of bikes I looked at and didn't get because of the coaster brake...
Old 08-16-2009, 06:53 AM
deacon's Avatar
minor bike philosopher
Coaster brakes are my rear brake of choice because they leave the accessory hole available to mount motors.
I have had them fail only when I had a chain come off. Since I often forget to check my bike, I try to always install a front brake of some kind.
Me and the Ebike
New Novel in progress blog...
Old 08-16-2009, 08:16 AM
silverbear's Avatar
I have coaster brakes on both my old Schwinn Americans, came as the only brake. I like them, but also agree that especially with higher speeds of a motored bicycle you need a front brake, too. I found new old stock adapters which allowed me to mount front caliper brakes on both of them. I find the combination entirely adequate for my usage. I don't anticipate the need for quick stops, just certain ones. I found the adapters on eBay and got nice wide reach pyramid calipers from bikeworldusa.
Silverbear
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 08-16-2009, 08:19 AM
Oh yeah, quite a few beach cruisers have them, also. In my old age I've started to forget things. What's my name again?
Yeah, they're definitely the most space efficient brake ever invented. BTW, Deacon, I think I'm gonna petition Paul to have the words right below your name changed to 'major bike philosopher'.
Robert
Old 08-16-2009, 11:24 PM
tyrslider's Avatar
They're ok as 1 part of a pair but I personally don't lik'em. Too many people rely on just a coaster and that's very dangerous. I'm really surprised at how many folks think that it's a good idea to find the cheapest bike w/ the cheapest componants and that's the one they want to strap a motor to!
FireBellyCycles.com
  #9 (permalink)
Old 08-17-2009, 12:11 AM
silverbear's Avatar
Well. I have to take exception to that statement. Just because a bike comes with just a coaster brake shouldn't rule it out as a good candidate for having a motor. My old /schwinn Americans are not cheap bikes. Made in 1963 in Chicago, they are still solid frames. I could spend a lot less for new ones. Having added new heavy duty rims, good tires and front caliper brakes, I think they are both pretty safe rides. None of the bicycles out there in stores were made for motors, so we have to make changes, improvements, watch every nut and bolt and constantly monitor the status of things. A front brake is necessary, but caliper is fine along with the rear coaster brake unless you are going for china girl bicycle land speed records, which most of us are not doing. I have no interest in going 40mph on a bicycle. I think most of us just ride these and enjoy them and are not pushing things to the limit, in which case a rear coaster brake along with a simple front caliper brake is adequate.
Silverbear
  #10 (permalink)
Old 08-17-2009, 01:55 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Coaster brakes are perfectly fine for MBs... You should always add a brake to the front wheel!!!
I read somewhere that the front brake on motorcycles & bicycles is responsible for 75% of the stopping power!
Also, I'd like to add to this, that in my experience, when coaster brakes on MB's get hot, they can seize up & lock up the rear wheel!!! (not just fade)
If you use one, ADD A FRONT BRAKE!!!
