Coaster brake danger!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Has anyone else had trouble with the rear coaster brakes on their bikes? Bean Oil (Chris) & I both had ...
Old 04-14-2008, 10:31 AM
VENICE BOY's Avatar
Custom Builder / Dealer
Default Coaster brake danger!
Bean Oil (Chris) & I both had our rear brakes lock-up on our saturday ride at the beach...
His rear wheel skidded to a stop, & my pedals locked and started turning & threw me a little into the air!, I landed on my butt on the seat and started dragging my feet like Fred Flintstone to stop!!!
We are both currently buying new rear wheels, & I am having a front wheel built with a old drum brake in it.
(I think a drum is the best way to go with a springer fork.)
If anyone has a bike with a rear coaster brake, I would advise that you have a front brake too!!
Any thoughts?
www.VeniceMotorBikes.com
Old 04-14-2008, 11:30 AM
deacon's Avatar
Default Re: Coaster brake danger!
I have both because I broke a chain once.. Never had them lock down and two at the same time would be vegas jackpot odds... go figure... glad no one was hurt.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
Old 04-14-2008, 01:06 PM
Motorized Bicycle Apprentice
I was surprised to hear about Norm's failure... I was on a different route home that afternoon.
My brake's issue was more of the same that I've had before (cheap HI STOP junk's brake shoes gouging the iron drum inside the hub) so I bought a Japanese-made Shimano coaster brake rear wheel.
Now all I need is the proper-sized rag joint; I misplaced my original rag joint then ordered another which wound up being a much larger bolt circle and basically unusable without mucho modification.
Old 04-14-2008, 01:47 PM
deacon's Avatar
rag joint?
Old 04-14-2008, 04:58 PM
Bikeguy Joe's Avatar
Fiber rubber thingy.
Old 04-14-2008, 05:32 PM
ran49's Avatar
Right now I'm relying solely on my coaster brake.Looking to put a drum brake hub on the front wheel.I did score a nice coaster hub from a guy on a bike forumKogswell Cycles but to avoid downtime with the weather just getting nice, I think That might be a good project for next winter.Ron
Old 04-14-2008, 09:36 PM
Easy Rider's Avatar
My bike only has a coaster brake. I've had many close calls that's why I'm installing a front disc brake. My latest was on our Santa Cruz ride. We were flying at full throttle for a 1/2 mile and when I decided to let off the throttle, my throttle stuck at full throttle. Then was I was trying to slow the motor down by braking. My coaster brake arm's bracket snapped and the pedal almost kicked me off the bike. I evenually got the bike under control and haven't rode it since.
But I am in the works of upgrading my braking system!
Old 04-14-2008, 09:56 PM
Norman's Avatar
LORD VADER Moderator
That will make the old Pooper pucker!!!!!
norms-iron-works.tripod.com
  #9 (permalink)
Old 04-14-2008, 11:23 PM
Easy Rider's Avatar
Actually I sharded!
  #10 (permalink)
Old 04-16-2008, 12:44 PM
D.J.'s Avatar
For my "rag joint" I used the soles from an old pair of slippers . The material is much thicker than that supplied with the kit . You can put the holes anywhere you want . An other choice is industrial floor mats used to relief foot fatigue . One small mat will provide enough material for several kits . .... D.J.
Similar Threads
Moutain bike - clutch/brake lever?? Pablo Mounting Techniques 20 06-29-2008 07:28 PM
Installed my dual brake lever Pablo Motorized Bicycle General Discussion 9 05-16-2008 01:14 PM
Front Drum Brake Autocycler Motorized Bicycle General Discussion 7 02-22-2008 08:54 AM
